Results 1 to 7 of 7
    Tools To Cut Heaksink block
    I have a square aluminium heaksink which I remove from my cpu cooler. I would like to use it as heaksink for my LED light project. Problem is, I have a round casing. What would be the proper tools to cut it into the shape and size I wanted! Thank you all!
    Reputation: zen bicycle's Avatar
    Dremel tool, or metal snips. Metal snips would be a little harder, but cheaper if you don't have either.
    Can I just check you're not cutting it down to fit inside your housing?
    relax
    Reputation: jeep's Avatar
    Sep 2004
    Quote Originally Posted by rottweiler
    Hole saw on the drill press, works well.
    I bought myself a dremel but I am still trying to figure out how to use it lol.
    Yes, I'm trying to grind it down slightly to fit into the housing. It was a square heat sink, I used a coping saw to cut it to the shape I wanted but it is slightly too big and too "gagged" to offer proper heat transfer to the case.
    I have tried metal snip, won't work (heatsink is 3mm thick). Blunted the blade.
    Singletrack Daydreamer
    Reputation: rockymtnway's Avatar
    Not a cheap option, but a great tool to have around, a bench sander.
    Train 'til you puke. Cheat to win. Party like a rockstar. We miss you, Jan!
    A fairly cheap option is a vise and file. It may take longer, but you will have excellent size control for a good fit. Your best bet really is to learn to use that dremel, with eye protection!
