Results 1 to 14 of 14
    Reputation: bonesetter2004's Avatar
    Superstar Components 1K Lumen LED
    Another 'cheap' manufacturer. uses a Sony battery too so I understand http://www.superstarcomponents.com/Products.html
    Where'd you get the pic? Is it yours?
    What he said...
    The website says they aren't available yet, so how'd you get yours and how much are they going to cost? Is yours a working model? Beam shots?
    Looks cool and I like that you can use a wide range of battery voltages.
    Thanks for the info and keep us posted.
    Quote Originally Posted by fevans
    They emailed me this info $300 without the battery - no thanks otherwise sounded good.:
    Thank you for your enquiry into Superstar LED lights. Superstar Components
    are the UK distributor for a new brand of high power UK made LED Bike
    lights. We offer full spares and repair facilities and a comprehensive
    warranty for peace of mind.
    The current date for release is end of February, but this depends on the
    arrival of certain parts.
    They use 4 Seoul P4 LEDs and use microprocessors to regulate the voltage and
    temperature, rather than crude and inefficient resistor setups used by other
    companies. The boards will be machine manufactured in a specialist factory,
    to keep quality control perfect every time. 1000 Lumen output, on full
    power, with a selection of lower power settings for longer life.
    The headunits can be purchased separately for use with a wide band of
    voltage batteries, for around £150 and the complete kit with Li ion
    batteries will be around £250.
    They will be packaged in a CNC aluminium casing and will come with a
    comprehensive selection of accessories like car chargers and helmet mounts
    as standard.
    Please sign upto the shop newsletter for the latest news.
    All the specifications and details can be found on our website as soon as
    they are released:
    Seeing as the P4 is only good for 240 lumen on a good day, I think they need maths lessons.
    Will be more like 800 lumen in practice, with a good battery and assuming they got good LED's too.
    My riding buddy has the first in th UK. I'll get him to take a beamshot
    and B+W too
    Reputation: RedBlueGreen's Avatar
    For 250 quid I'd sooner buy the new Hope LED light (also not out yet). Reason? I'd have more trust in Hope to honour warranty claims, provide upgrade options etc. Plus I've seen some Superstar brake pads and they weren't great...but that's another story.
    [SIZE=2]MCM#: Googolplex[/SIZE]
    Quote Originally Posted by RedBlueGreen
    Tha Hope looks interesting, but isn't out for another couple of months which is towards the end of the night season.
    I've just gone with the iBlaast. This has a proven 4 year record with plenty of excellent feedback here, and it's upgradeable. For a helmet mounted HID bar mount complement I'm sure it'll be fine...
    The hope looks like a posh version of the superster.
    and B+W too
    Quote Originally Posted by bonesetter2004
    Chain Reaction say the Hope 4 LED will be out in 12 days from now: "Due In Stock 30/01/2008".
    I agree with you Bonesetter, the iBlaast is a Blast
    Copied from Singletrackworld forum ealier today
    Reply from fruit, owner of superstar components to This Thread
    Everything with "1000 Lumen will be using 4 seoul P4 Leds
    Everything is availible off the shelf to fit these parts
    The complicated bit is to regulate the heat build up. You can do this
    really crudely and never get the full light output. or use sophisticated
    microprocessors to measure the current and voltage draw to regulate them.
    Our lights are built with the latter method and so are lupines, Im waiting
    for a set of hopes to investigate them
    Cheers, Neil (superstarcomponents)
    My response
    Using the Seoul P4 LED's, the lamp will not achieve 1000 lumen output. The P4 Will achieve a maximum 240 lumen at 1 amp drive current, that is assuming that they are the highest bin emitters too. A likely average will be more like 225 lumen as the Seoul binning range is quite large compared to the much tighter Cree. Only the latest Cree R2 emitters can achieve approximately 245-270 lumens, per LED at 1 amp.
    Also when you take into account the inefieciency of the optics, that takes off another 5-10%.
    A more realistic output for a quad P4 setup is nearer 850 lumen, which is what lupine claim for the Wilma, also using Seoul P4 emitters.
    The above also applies to the new Hope.
    I was speaking to Chain Reaction a few days ago about something else and asked about the Hope release date. They said Hope (and other manufactures) are usually optimistic about when product will be ready.
    They said it likely the new Vision will not be out for another couple of months PAST the 'due' date of the 30th...
    Another reason I went with the iBlaast
    Thanks for the thumsup BTW
    and B+W too
    I've never been a fan of tiny companies that make very bold claims for brand new products...especially when their claims aren't technically capable of being achieved. I might be being overly cautious but if the math doesn't add up...it doesn't add up. Plus I don't like being a beta tester when paying top dollar.
    Good job I'm not in the market for a new light atm, but by September time I'll be looking to build my own with all the satisfaction that will bring.
    Yes, I've been following the DIY threads with some interest. It does look fun being able to build your own, might well have a go...
Hot Deals
Contests
Latest Mountain Bike Articles
