Page 3 of 3 FirstFirst 1 2 3
Results 51 to 62 of 62
  1. #51
    Quote Originally Posted by pucked up View Post
    Does anyone have any links for power wiring / cables?
    I second the El34 suggestion and add another one.
    I get silicone wire from hobbyking.com. Also good for chargers and battery packs ect.
    I use servo wire for internal wiring.
  2. #52
    Just a quick bit of praise for ebay seller "boltmeup". They've got a good selection of metric SS bolts, nuts, grub screws, etc. They're UK based, but I think they ship internationally. All that's not the reason I'm writing this, though. There was a delivery mixup on a recent order, and they bent over backwards to make things right for me... that's the kind of service I really appreciate.
    The study du jour: can one's reputation be artificially inflated by simply putting a request for rep in one's sig?
  3. #53
  4. #54
    Reputation: marpilli's Avatar
    I forgot how much fun DigiKey is. I could spend a paycheck in there. And, their first class USPS shipping is cheeeeep....
    Just ordered some small project boxes with flanges to try and DIY an in-line switch.
    1.378" L x 1.378" W (35.00mm x 35.00mm)
    Height 0.787" (19.99mm): 1551MFLBK Hammond Manufacturing | HM1058-ND | DigiKey
    Height 0.591" (15.01mm): 1551NFLBK Hammond Manufacturing | HM1057-ND | DigiKey
    EDIT: I built an in-line switch using one of these housings and I really liked how it turned out. More info: CatEye Double Shot XM-L (U2-1C) Upgrade
    Sticky request: DIY parts suppliers, vendors, etc.-1551nflbk.jpg
    Contact information: http://about.me/marpilli
  5. #55
    I'm your density
    Reputation: random walk's Avatar
    Alternatives for waterproof connector cables (cheap with free shipping, at least in the U.S.):
    Amazon.com: Male Female Plug 2 Pin LED Waterproof Connector Cable Black: Electronics
    If you want something for a pack to be charged with a balance tap?
    Amazon.com: Gino LED Light Strips Male Female 3 Pin Waterproof Connector Cable Black: Electronics
    There are others in white, with 4 pins, etc.
    edit: I just noticed they ship from Hong Kong, so probably free shipping and a long wait for everyone!
    edit 2: I ordered some. They are 22 AWG. The leads are about 6" long.
    "Two wrongs don't make a right, but three rights make a left."
    Ty Webb
  6. #56
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Boxes
    I was recently informed about this company:
    ZERO Manufacturing, Inc. - Deep Drawn Enclosures
    their product of interest is drawn aluminum cases of many, many different sizes and wall thicknesses. I have no idea if these are suitable for bike lights, but they can be purchased with matching covers. Could be worth a look.
    Walt
  7. #57
    Reputation: Ofroad'bent's Avatar
    Good XML optic:
    Good bright spot and some useful spill.
    If the link gets removed, look for LED-DNA and 10 degree "reflector"
    5PCS x 10 Degree 21mm Reflector Collimator LED Lens For Cree XML XM-L LED | eBay
    EDIT- The vendors do have more of these if you contact them, even though the listing seems to have ended.
  8. #58
    Oct 2012
    dealextreme works for me. Low prices and many DIY parts,. (emitters, batteries, drop-in modules)
    Especially good for mods or experimental works.
    sorry, I can post the link, Im a noobie here.
    dx dot com
  9. #59
    May 2013
    until now i have seen only 1 guy who is using LIPO cells , the rest is all still working with the Litium -Ion cells.. Why >?
    I use LIPO for everything .. powering up the lego trains for my kids light systems for the bikes , they are cheap . powerfull good to charge and the last long ..
    Go LIPO..!
    Jeroen
  10. #60
    Nov 2012
    ^^ +1
    I add the source for Lipo and various Lipo monitoring tools & connectors.
    and some refresh to LED drivers and control: pcb-components in Europe/Germany.
  11. #61
    Oct 2011
    2s2p protection board supply anyone?
    Seen plenty of Chinese ones on Ebay. Anyone used them?
  12. #62
    Nov 2012
    Yes, just be careful with the cut-off voltage. I use PCBs from tchwarehouse-au and hunk_lee ebayers with li-ions and li-pos. 2s2p protection is the same as 2s1p or 2sXp because of the parallel cells connection and how it works.
