Results 1 to 11 of 11
Thread: ssc p7 optic,s
    ssc p7 optic,s
    hi all
    what optics are Available for the p7s i,ve a 35mm reflector but was woundering weahter to use an optic/lens for my next build.
    cheers thwang
    Carbon8er
    Reputation: El34's Avatar
    Jan 2009
    Do you mean some sort of piece of glass over the reflector other than just a flat piece of glass?
    You might have the same 35mm reflector I use from DX
    I machine the front of the reflector and then silicon in a recessed piece of 33mm glass.
    Hard to see, but there is a piece of 33mm glass on the front of this reflector
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, look here
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    hi el34
    yep i have the same reflector i would like to use an optic.
    hi msxtr
    the link do,s work or it might be my pc?
    simon
    Carbon8er
    Jan 2009
    I still don't understand what you mean by optic?
    Can you describe what you want to fo?
    hi
    optic same as a carlco lens
    Dec 2005
    He doesn't want a reflector for his next build but is interested in using an optic.....something like these but for a p7:
    http://ledsupply.com/led-optics.php
    Carbon8er
    Jan 2009
    ah, ok, I did not understand.
    Thought he wanted to add some sort of optic to his reflector
    Reputation: yetibetty's Avatar
    thanks yetibetty
    do you know who has them in stock?
    thwang
    Spanish biker
    Quote Originally Posted by thwang-01
    hi el34
    hi msxtr
    simon
    Sorry, here the good link
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
