    Source for DIY Niterider Connector
    I did some searching and didn't come up with anything, is there a source for the connector that Niterider uses on the Minewt and Sol lights? I need an extension and it's nuts what they are charging for these things!
    Feb 2006
    I'd love to know too. $30+ is reeeedickulus
    Those connectors kind of suck. Best bet is to get some Binder 712 snap type or 719 screw type connectors. They are IP67 and they don't fall apart when you hit a big jump.
    Do It Yourself
    Reputation: Homebrew's Avatar
    If you just want an extension, you can just cut the cable and add in whatever you want in the middle as long as you keep the wiring the same. With a little heatshrink and RTV, you should be good to go.
    Long Live Long Rides
