Results 1 to 13 of 13
    Single XML + Lflex + Laura
    Here is my take on a Single XML + Lflex light. It's kind of a hybid of Trouties and Matt's designs. The led is glued to a heat sink, sled combo. The power connector is in the plastic end cap and the switch it located on the top.
    Beam shots to come....
    Reputation: znomit's Avatar
    Quote Originally Posted by KBARK
    Nice.
    I think there will be a lot of these made!
    Dirt Deviant
    Reputation: savagemann's Avatar
    Looking good.
    Is that a reflector mount I see?
    I take it you used the Laura RS?
    Where did you get the black tubing?
    Look, whatever happens, don't fight the mountain.
    Super cool and agree with Znomit about there will be a few like that built .
    have you broken the top right corner of the Laura ?
    Reputation: bravellir's Avatar
    Nov 2008
    well done kbark
    Quote Originally Posted by savagemann
    Looking good.
    I think its a chair leg
    There will be a lot of this designs for sure
    Reputation: Ofroad'bent's Avatar
    Did you use the front of the sled for the XM-L and the back for the driver?
    It's a smart idea, and then you can place your switches and cable wherever you want.
    It's less work than fitting everything in a small sled.
    I bet George is hoping there will be a bunch of these made!
    Yes, I used a reflector mount for the bar mount. I used a Laura RS that I got from Newark.com but I managed to break the corner test fitting it. A few more are on order.
    The black tubing, I found at work in the scrap pile. It was part of a security fence I believe.
    The XML is on a "L" bracket that has a 8mm slug of aluminum glued to it. The Lflex sits on the bottom of the housing.
    Nice looking build....
    Reputation: HEY HEY ITS HENDO's Avatar
    thats great!!, ..the chair leg comment made me laugh!!
    i think the black epoxy coating will insulate it though......
    ...Scun.thorpe, UK
    May 2010
    Steel tubing?
    Reputation: BrianMc's Avatar
    That is a nice effective first build concept, for sure.
    Heat. Proof is in the operation. If it runs cool enough, epoxy be darned! If not. a disc sander and drill will remove it. Polished Al can look cool an BE cool(er). The idea of sneaking a chunk of chair leg off someone's chair to build this... priceless!
    Esp[ecially if they were drinking and in the loo when you do it!
    I know it's a little rough and the black aluminum is not the best for heat transfer, but I wanted to test out the design before I cut up my good raw aluminum stock.
    During my testing, the thermal protection of the Lflex cut the power at 70c and the case temp. was 60c. Not perfect thermal transfer but not too bad either.
    As many here have said, a little airflow goes a long way. With a small desk fan blowing on the light the thermal protection never kicked after one hour on high.
    All of my testing may be for nothing since most of my night rides here in N.C. are in temps near or below 50F. Testing was done indoors @ 70F.
    Nov 2008
    Quote Originally Posted by BrianMc
    ...sneaking a chunk of chair leg off someone's chair to build this... priceless! .
    bahh.. I'm dumb.. I bought a chair leg from a hardware store..sould had done your way
