Results 1 to 9 of 9
    Reputation: deesta's Avatar
    Show me your remote switches....please
    Hi all
    New helmet light under design. Trying to keep it nice and small and one of the major factors for size are my switches.
    I know there have been a few great remote switches done so was hoping some of you could post up a few details etc for me to have a look at? Needs to be a momentary switch..
    Cheers
    Steve
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Here's a simple switch using a tactile switch inside some heatshrink
    This switch was made using a smaller tactile switch but mounting it inside one of those cheap handlebar flashers. This switch also had the stat led mounted inside so I can see the low power warnings remote to the light
    my last couple I've just rewired the Easy2Led remote switch - but that's only cause I wasn't able to solder the leads that came with those switches very well.
    I've also made a couple very similar to brad72's tactile switch and heatshrink - but I take the tac switch and pot it inside a nylon washer or nylon nut using hot glue. Then I put a little piece of foam rubber over the button before heatshrinking.
    Attached Thumbnails Attached Thumbnails Show me your remote switches....please-2013-01-26_09-56-35_384.jpg
    Reputation: HEY HEY ITS HENDO's Avatar
    As good as tact switches are,
    i`m surprised nobody has done a reed switch version
    here`s my offering, .... remote bar switch
    ...Scun.thorpe, UK
    May 2005
    Quote Originally Posted by HEY HEY ITS HENDO View Post
    Don't reed switches require a magnet to actuate?
    Reputation: beecrazy's Avatar
    Cheapo switch
    I used a cheapo clicky switch, glued a nylon waher to it, liquid electrical tape to make water resistant and a flashlight button super glued to it. (I didn't have any heat shrink tubing that would work......)
    On the back some velcro to mate to brain bucket (not shown)
    09 Specialized Rockhopper Comp 29er
    16 Rocky Mountain Blizzard -30
    Some great little switches there...thanks guys
    I've got loads of the bFlex switches so will look at going down that route I think.
    I'd avoid the old bflex switches - I used one in a bar remote and for about a year it would bounce enough on the bumps to change modes. It's stopped now (no idea why) but it was damn annoying while it happened. No idea if it was due to my housing design or the switch itself, but decent momentary switches are so cheap it doesn't make sense to use something that might not work as intended.
