Results 1 to 41 of 41
    Seca 700 or Dinotte 800
    With 400-450 dollars to spend which set up do you like better for singletrack use?
    L&M Seca 700 mounted on helmet
    Dinotte 800 mounted on helmet
    Dinotte 400 dual mounted on bars and helmet
    Cost for the Seca is slightly higher but I seem to be drawn to it.
    I like the dual set up but not sure if two 400Ls will equal the brightness of a single 800 lumen light.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Subscribe.
    bi-winning
    Reputation: rkj__'s Avatar
    no need to enter a message.
    Quote Originally Posted by Enel
    Subscribe.
    thread tools --> subscribe.
    ...personally, for singletrack, i want a helmet light, a lightweight helmet light. If a single lightweight helmet light is not enough light, add another light to the bars.
    aka, I vote for 400Lx2.
    I'll add option 4 and suggest the AYUP MTB kit. They are superlight and put out great light. The bar and helmet combo is the way to go.
    What do you mean subscribe?
    Reputation: znomit's Avatar
    I'd go dual 400s. Or when I win the lottery 800 on helmet with a narrow optic and seca on bars.
    actually lotto is 30million this week so I'd pay a helicopter pilot to ride above me with a billion candlepower spot.
    He is subscribing to this thread since he is interested in the responses. I prefer one bright light on the helmet and would probably go for the Seca but not if it were considerably heavier than the 800L. I would guess the Seca has better peripheral light since L&M values that quite a bit.
    400L isnlt enough for me so I'd look at the other two and compare weight. That may give one the edge if there is a 20 + gram weight advantage. I'd also consider the beam pattern. I'm guessing here based on the products from both these companies but the Seca will probably have better peripheral light. If true, that would give it the edge.
    The distance that the light travel effectively will probably be pretty close. I'm just getting back into the diff lights and have little experience with these two so will hope that others have hands-on experience.
    For the ultimate setup I'd go with two lights but 400L isn't good enough for me. The 600L barely does it though a dual 600L would be fine. For one light, I prefer a minimum of 700-800 lumens and for two lights, each one has to be ~600 and up.
    Have not seen the Dinotte lights, but I would use a Seca 700 on the handlebars. Why? Because when you only use a light on your helmet, you don't see any shadows in the terrain.
    This is the Seca 700 on max:
    9 feet to the first cone, then 9 feet apart. 50 yards to the pole.
    Canon 30D on tripod, 30mm Focal length.
    Whitbalance daylight, RAW..
    4 second exposure, aperture 8, ISO 800.
    Picture is not tweaked in PS, direct from iPhoto to Picasaweb.
    (Picture: GGeir Anders Rybakken ěrslien)
    bi-winning
    Quote Originally Posted by C. Alshus
    But seeing shadows in front of you is useless if you cannot see around the 180 degree switchback.
    Agreed- I can;t use a bar-only light either....even when I know the trails pretty well. I have to peek around boulers and tight bling switchbacks before my handlebars are turned that way. Even with huge spill/peripheral light, the bar light can't go past high obstacles till yoru bike is turnerd around it and I need to see what's ahead before that happens.
    The trails in the Midwest may be twisty but those are rideable with a bar light- been there and done that. I still prefer a helmet-only light but when I moved to Colorado, a bar-only light is asking for trouble. My x-ray vision is getting worse as I age....I use a helmet and bar light but am/was fine with a helmet-only light as long as it has enough peripheral light.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Quote Originally Posted by Flyer
    Quite the generalization there isn't it? I by no means have ridden "all" trails in midwest, or any other region, but, I do find it highly annoying when horrible stereotypes like that come up.
    Especially for those of us who like to ride a wheelie now and again, or manual a dip, bunny-hop a log, etc., etc. Whether riding a fire-road, or switchback, a bar mount won't serve any purpose when aiming to the sky.
    ...sorry, had to rant... reminder to keep an open mind.
    And on topic, IMO, I would not run the Seca 700 as a helmet mount... too big and tall. Same with 800l I think, although I've yet to see one of those first-hand.
    But, if you're going for a bar-light, the optics of that Seca 700 are pretty awesome...
    Just from your list, I'd probably go dual 400l. Great price, extremely versatile set-up, comes with wide and narrow lenses, vertical or horizontal mounts, helmet mount, two batteries of your choice, etc. And, later on down the road, if you decide to go for another light from Dinotte, everything is compatible if you simply want to purchase a solo 800l or 600l light engine (delete charger, battery) which can save you some cash. (and you can even get their head strap and use the light while backpacking/camping/hunting/etc.!)
    Or if you could swing it now, 600l bar/400l helmet. Not too much more than a single Seca.
    Or, another great option in the same $500 range, you could also consider ordering two of those NiteFlux Photon Max lights ($249USD each). Now that would be some serious output for the price! I kind of looked into it myself. One helmet (although I'm quite unsure of size), and one bar-mount.
    You can also look at the offerings from Hope... (although reviews seem to be hit or miss), but their new "Vision 2" apparantly uses similar set-up and same LED's as Dinotte 400l. But, their battery run-time is shorter than 400l, and if you get two of the Epic with larger batteries, you're looking at over $600USD. yikes.
    If you're looking in that $500 range and would consider a solo light, I'd also take a gander at one of those iBlaast II, or the Exposure Max (for bar).
    I'm not too sure what the AYUP is, brewer90, can you elaborate?
    Anyway, keep us updated, I'd be interested to hear which route you take. I'm currently running a wilma 7 on my helmet, and soon to be trying some of those cheap MTE P7 torches on the bars to replace old halogen... but, my girlfriend is in somewhat of a similar situation as you, also looking at the dual 400l's (which I would swipe for my bars when she's not riding, haha! ), and a local shop owner I know just swapped all of his HID stuff out for the new Seca 700 and a Stella 200.
    Schralp it Heavy.
    Thanks for all the responses. I went ahead and ordered the Seca 700 from REI using their 20% off deal for members. I think I will give it a try on the helmet for now and see how it goes. If I do not like it on the helmet I will probably move it to the bars and look into a small light for the helmet.
    nimble biker
    Reputation: Picard's Avatar
    Apr 2005
    this is the best test photo of Seca 700. I really like it. I will buy it for sure. It looks brighter than Dinotte 400L.
    A flat trail can be ridden more easily with a bar light- that's all I'm saying. I'd much rather just have a helmet light- on ANY trail. Here in Colorado, just having a bar light would be suicidal. I now use two but if I had one, I'd always opt for it on the bar.
    The Seca beam looks pretty good. I hope to get my hands on one to see how it compares to my Wilma....just to compare. I'm finally done with light UGI...I'm 99% sure.
    Quote Originally Posted by BikeSATORI
    where can you get the niteflux for 250?
    mtbr remember
    Quote Originally Posted by jmeitz
    chainreaction... (who actually has great international rep. and service.)
    they've got a few other hard to get items too, like schwalbe tires for example, which are currently near impossible to find in NA due to low stock.
    Hey, just looked again myself... Price actually dropped another $3USD on about everything there... this market is insanely unpredictable. Didn't expect it would effect ordering from CRC that quickly though.
    Schralp it Heavy.
    Good thing we ride in areas other than Colorado... 38 million folks here in California, not many of our mountain bike trails are flat, and a br mount with wide angle lense LED's plus a few throwers on the helmet seems to be what I see on most of my night rides by the really sick, fast, crazy riders that like to go OTB. The more sedate among us with common sense slow down and get by just fine with handlebar mounted wide angle flood type lights with 4 to just under 600 claimed lumens.
    I've no doubt that the L & M is a fine light... they strive for best in class, but they are priced on the medium high side... still a better value than Lupine. Their ARC HID was the best HID I've ever ridden behind, but if you crashed and broke a Welsh Allyn Mini HID bulb, the replacement was about $130 for the HID and ballast.
    It really isn't a question of flat trails. Here is what I find- here in CO, a lot of the trails have steep and tight switchbacks or fast turns but the view around many is obstructed by boulders or the side of the mountain itself. While I could ride with just a bar light on the twisty trails in Kansas City, I find it really hard to do that here without having too many "oh no" moments. It seems that the light beam is obstructed more and if I don't have my helmet light on, I can't see around turns well enough or rather, fast enough.
    Almost every single-light rider here (that I know and see) uses a helmet-mounted light...for good reason. And no, we don't slow down much at night or you fall behind too much and then every noise makes one think about Mountain Lions and the errant Bear. No reason to slow down if the lights are bright enough and one has a helmet-mounted light as well. We ride at about the same speed- day or night. Forced slow rides are pointless. I climb slow enough.
    A trail like Green Mountain can be done with a bar-only light but not too many trails here are that wide and open.
    if you dont have bar and helmet lights your "off the back"
    He be a moose too.
    Reputation: pinguwin's Avatar
    I do a fair amount of night riding in the midwest and there is no way I'd only go with a bar light on any but the easiest trails. I was in a race on Friday night where there were numerous switchbacks with 6 foot diameters, no way to possibly do those a bar light only. So much of the midwest's trails are very twisty and a helmet mount is a must. I have a L&M Arc and am trying to decide whether to take a trade in (1/2 price) for a Seca.
    It's also nice to have two lights in case one of them fails.
    AYUPs are LED lights from Australia but they have a US office and make the rounds at some of the 24 hour races. Each light head is a twin LED setup putting out 300 lumens. The three hour battery is super small - 2.5" x 1.5" x .75" and only weighs 100 grams including the neoprene pouch. The light is only 60 grams. Both of them on your helmet is less than just the lights of most other brands. I bought the MTB kit which comes with an intermediate light for the bars and a narrow for the helmet, a 6 hr battery, two three hour batterys, an AC charger and a 12V car charger. You can charge two batteries at once. There is no dimming or strobe option. The lights are just lights and come with a 10yr warranty. Both of them together provide plenty of light. They are simple and get the job done. They were reviewed in the MTBR light shootout but the LEDs are now Crees and are much brighter than the beamshots in the shootout which were Luxeons.
    http://www.ayup.com.au/lighting.php
    Woodlot local
    Reputation: BobRocket's Avatar
    If it was one light. I'd go with the L&M Seca, but 2 lights are better than one in most cases. Therefore I'd go with dual 400s
    I think L&M seca 700 has the best beam pattern for both helmet and handlebar mount. but it's still not as bright as 800L. and with 800L/400L package for $449. best deal so far.
    Quote Originally Posted by Sawdaddy
    Dinotte is having a special deal now. You can get the 800L and the 400L for $450-$500 depending on the options. http://store.dinottelighting.com/sha...unt2=447776436
    The 800L is a handlebar mount only light.
    Doesn't it use the same mount as the 600L? If so, then it should fit on the helmet using the 600L helmet mount.
    J
    comes with handlebar mount only, but you can still use the 2" diameter light on your helmet using the same mount as the 600L. 800L comes with medium flood lens.
    i just picked up the 800/400 dinotte light special, they arrived today. They are both very bright and can't wait to try them out on the trail...
    I was told from the company the 800L was a handlebar mount product only, but I just looked at their site and they do have a helmet mount for it.
    Woodlot local
    Quote Originally Posted by downhilldan
    I made a custom mount for my 800L for my helmet. Works like a charm and is super light.
    I'll post up some pictures of it later.
    This is my loam burner set-up. Dual 50W MR16s over-volted and a Dinotte 800L on the helmet. Easily a good 3000 lumens. I have no excuse for not being able to see the trail.
    Woodlot local
    Quote Originally Posted by eddielee70
    Last night I rode with my 800L and a friend had the Seca 700. The Seca has a nice beam pattern, but the 800L is definately brighter and has a whiter light color.
    The 800L and 400L for the money beats the Seca in versatility and usable light.
    Lumens are addicting. I've got a 600L and a 400L set up and now I'm lusting after the 800L or a Wilma.
    Riding at night is addictive. It's really fun after a whole summer during our long days here in the north, riding at night is a whole new dimension and just fun in its own right.
    J.
    mtbr remember
    Quote Originally Posted by BobRocket
    That's interesting you found the DiNotte to have a whiter light compared to the Seca. From what I've seen, it's a bit opposite IMO. Although I have not used an 800l, I've found all of the DiNottes to have a much "bluer" tint to them, including the dual 400l set-up I just recently acquired.... Maybe 800l is quite different?
    That is one h'UGE set-up you've got yourself there, dayum. You could set some night time land speed records or something. I like that, "loam burner". Cool! And I thought I was the cat's meow with a Wilma on the lid and dual 400l's on the bars...
    Schralp it Heavy.
    Woodlot local
    I guess I should have said the Dinotte is bluer in color not whiter....sorry.
    If I was using only one light, I'd likely pick the Seca, BUT I always run at least a bar and helmet, so the Dinotte set-up works much better for me (800L and 400L).
    Woodlot local
    Here are the beam shots.
    The light of the Dinotte is brighter and bluer, but has a standard 'round' beam. The Seca has a nice spread in front of the rider. The camera was slightly jostled when the Seca shot was taken and therefore isn't the perfect comparison shot. I was pissed when I viewed the shots on my computer. Maybe next time.
    Dinotte 800L
    L&M Seca 700
    FYI - Shots taken with a point and shoot digital camera. 15 second exposure.
    mtbr remember
    I gotcha. yeah, def. bluer in color, at least from what I've seen.
    DiNotte 800/400l combo is MUCH more bang for the buck vs. the Seca700, especially with their current sale price.
    Schralp it Heavy.
    Dinotte 800L
    L&M Seca 700
    That looks like an awesome trail Thanks for the beam shots!
    Hmmm... I think I like the colder temp of the Dinotte. Those Seca's look too yellow for my tastes.
    Plus you get more punch on the Dinotte.
    BTW, the seca 700 can be had for $315 after 25% cashback at ebay for 6 cell; and $370 after cashback for 9 cell.
    My take on all of this... Both the Seca 700 and the Dinotte 800L look like nice lights. The Seca uses it's specialized optics to create a special "MTB specific flood pattern"that is perfect for bar mounting. This pattern of light has many advantages as it keeps the light widely spread out in front of you. This means more light on the trails and less in the upper trees where you don't need it. Couple this with the warmer bin LED's and you should noticed less reflected glare which should translate over to better night vision for most people. The Seca should work really well when used in combo with an additional helmet mounted light.
    The Dinotte 800L on the other hand uses it's optics to "push" the light out ahead of the rider. With 800lm of light it has a lot of light to push. Others have noted that the beam pattern is not as wide as what they might have wanted but with 800lm you are going to have lots of peripheral spill that should be wide enough for almost anybody. Others have also noted that a lot of the light from the 800L goes up into the trees. From the photos I have seen that looks to be true. No doubt there will be a glare factor to consider when buying this light. However sometimes the higher throw can be helpful. This is especially true when it comes to overhanging trees, spider webs, and rollercoaster type hills. I personally use a Dinotte 600L (standard) on the bars. While not as bright as the 800L it does look to use the same beam pattern. As a bar mounted light my 600L works great and I have no plans to upgrade at this time. I have no doubt that the 800L is brighter than the 600L and will probably out throw it. For me that's not an issue as long as I have a bar mounted system that can throw for at least 100ft. while on the trails. From the photos I've seen, all of these lights.. ( Seca 700 & Dinotte 800L ) are going to do that and more.
