Results 1 to 3 of 3
Thread: run time?
    Reputation: hizzity's Avatar
    Mar 2006
    run time?
    I have looked around trying to find what the equation for finding out run times is but I can't find it. anybody know it? I am building a 3 cree q5 system running at 1ah and using a 14.4 3800mah battery. I am thinking that since it is running a 1000mah and should get 3.8hrs?
    It's go time
    maker of trail
    Reputation: essenmeinstuff's Avatar
    Quote Originally Posted by hizzity
    Your method is wrong, but you've come up with probably an accurate number lol.
    Unless you're running a linear regulator, calculate your LED power (LED voltage times 3 times the current in A), divide it by about 0.9 to take the efficiency of the regulator then that is the power drawn from the battery. Divide that power number by the battery voltage, and you have your actual battery current, divide this by 0.9 to take your battery discharge efficiency and you have your "drain" on the battery.
    Mar 2006
    Quote Originally Posted by essenmeinstuff
    Cool, thanks. It looks to be about 3.6hrs.
    It's go time
