Results 1 to 3 of 3
    Mar 2011
    A ready made housing?
    Has anyone tried using one of these pond lights as a basis for a 3x xm-l build? It looks easy to disassemble, waterproof, & made of Al. From other descriptions it is about 75mm x 75mm. I have not seen how the original led's are attached to the housing. However, if the front of product mirrors the rear (as in the photo) this could be an excellent host for us non-machinists.Amazon.com: Lemonbest® Remote Control 10w 12v Ip68 RGB LED Underwater Landscape Fountain Pond Light Color Changing Light Kit: Home Improvement
    Looks interesting, if perhaps a bit big. Have you seen the alternatives from easy2led.com?
    The study du jour: can one's reputation be artificially inflated by simply putting a request for rep in one's sig?
    Here is a step-by-step assembly of a triple XML: http://forum.fonarevka.ru/showthread...17762&langid=1
    CNC LED light housing for DIY projects
  1. US made vs made elsewhere (with a twist)
    By dv8xin in forum Bike and Frame discussion
    Last Post: 03-29-2013, 03:02 PM
  2. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  3. Replies: 38
    Last Post: 11-05-2011, 06:09 AM
  4. Non-custom made steel frames made in the US?
    By bwheelin in forum Bike and Frame discussion
    Last Post: 04-03-2011, 01:11 PM
  5. Rear Derailler Issues: dirty housing, full housing, new housing?
    By TwoHeadsBrewing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2011, 10:49 AM
