Results 1 to 3 of 3
    RAM Mount help required
    Hello I am in a bit of a rush to buy a RAM Mount for my Garmin Etrex Legend CX. I was wondering if somebody might be able to shed some light onto which one I require.
    First is RAM-HOL-GA5 which supports:
    Garmin eTrex Series
    Garmin eTrex Camo Series
    Garmin eTrex Summit Series
    Garmin eTrex Venture Series
    Garmin eTrex Legend Series
    Garmin eTrex Vista Series
    Second is the RAM-HOL-GA16U which supports:
    Garmin eTrex Legend C
    Garmin eTrex Vista C
    I cannot personally tell any difference between the two so I cannot figure out which on I require. I already have the Garmin bike mount but it rattles around quite a bit so I am hoping that this will be a bit more solid.
    trail rat
    Reputation: slocaus's Avatar
    It will be more solid. Companies are know for posting wrong or the same pictures of different items. Go with the descriptions and it is obvious which one you need to fit your Garmin eTrex Legend Cx!
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    OK thanks for that. Well I had ordered the second one inbetween my post and your answer. The reason why I was not 100% sure was because the Garmin bike mount (the one which replaces the battery cover) will fit the Legend C but not the CX (an adapter is required for this instead). I thought if they are a slighly different shape on the outside then maybe the RAM mounts would be difference also.
    OK thanks again.
