Your 18650 will come off charger around 4.2 volts. The XML operates around 3.2 volts. Leds do not do well over volted. It will get hotter brighter and burn up quickly.
Resistor would increase circuit resistance to offset the voltage of battery.
In general do not direct drive XML with 18650. Most likely it will burn up first time you run it.
depends on the LED's and some other stuff. you can overvolt some LED's a little more than others, if the amperage is kept low enough.
Since you didn't mention what LED's you were direct driving - it's hard to answer that question.
But - if you were running a pair of something like XR-E in series directly off a 7.4V pack, with something like a 2.2h pack, with no driver or resistor - I can't see how you were keeping them from popping.
You can direct drive an XML with an 18650 as long as the 18650 has enough internal resistance to limit its discharge current to somewhere in the neighborhood of 4A (you'll need a housing with good heatsinking). Lots of the ....fire cells fall into this range, though I have seen a couple that would go 5A. I have not tested any of the high capacity panasonic cells, they probably can deliver enough current to kill the LED. Add in wiring and a switch, each with their own resistance, and you gain a bit of margin. Do not add cells in parallel though. A parallel pack can deliver more current and the magic smoke will leak.
All this being said, IMO it is better to use a driver. The ability to use multiple cells, have different brightness levels, maybe temp sensing and voltage sensing is just too good to ignore.
I used to work in the car audio industry, I've had to explain the "magic smoke" principle to a lot of people that didn't know what I was talking about.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
