Results 1 to 7 of 7
    Quick Q on Camera settings
    Hi all.
    I'm wondering what camera settings, specifically, you guys are using for beam shots of the XP-G and XM-L LEDs. Please.
    ISO
    F?
    EXP
    W/B
    Thanks in advance.
    <a href="http://voracious-eater.blogspot.com/2010/11/recipe-angry-flapjacks.html">Luminous</a>
    May 2010
    MrLee.
    Thank you very much sir. Seem to be the old settings.
    I must have got my wires crossed as I thought a new setting had been agreed to cope with the higher outputs of the XP-G and XM-L.
    Obviously I was wrong.
    Cheers muchly.
    I think this is the thread you're looking for.
    MTBR Standard Camera Settings for High Power Lights
    May 2010
    Although I'm not sure anyone is using them.
    MtbMacgyver.
    Thanks for that, I thought there had been some discussion on this issue, hence my referring to XP-Gs and XM-Ls, although I had forgotten the 3000 lumen activation point for the alternative settings.
    Previous beam shots for lights with XP-G, on the original settings just seem so bright, but I guess its more about staying consistent and in line with the rest of the folk on here, so we can get a realistic comparison, as far as one can with pictures alone.
    Really appreciate the help guys.
    Thanks.
    I use 2s and white balance (can't adjust the rest) as a 6s exposure is way brighter than the light looks in person and tends to wash out the beam pattern. Most people on here are more interested in beam shape/ pattern than relative brightness, which can be affected by lots of other variables (humidity, terrain, etc).
