Results 1 to 9 of 9
    Jun 2013
    Question - Exposure Revo Mk1 Dynamo
    Hello, so I want to buy the Exposure Revo Mk1 Dynamo bike light.
    I also want to connect my Garmin edge 800 to it, is that hard to do when I also use The Plug II ? How should I wire it? I haven't got any experience with this..
    Thanks in advance!
    Reputation: ktronik's Avatar
    Just switch the input power between two plugs, for lights or USB, I offer a pre-made solution if you get stuck.....k
    Jun 2013
    Quote Originally Posted by ktronik View Post
    So I should connect the hub to the plug, and to the Plug II I can connect the Garmin with usb.
    How can I use the Revo Mk1 with usb?
    And can I just connect the Plug II to the dynamo hub, or do I need some different cables?
    I noticed that the Revo Mk1 also has a 'ouput' can't I just plug my garmin into that?
    So from hub to switch, that switches between the 2 outputs, put it near the fork leg, one output runs up the fork to the "plug" the other to the revo.
    The output on the revo is for a rear light...
    K
    Jun 2013
    K
    So what excactly is the switch?
    Any toggle switch rated over 1A will be fine...
    Here in the pic you can see a regular SPDT switch w center off, this one is not for 'the plug', but for a battery charger and a revo, and mounts under the stem, as a 'spacer', but you get the idea...
    Jun 2013
    Again, I'm a real newbie on this.. Sorry for that
    So;
    Dynamo -> switch -> The Plug -> Edge 800
    ''''''''''''''''''''''''''''''''''''''''''''''Revo
    Is there a switch available that I need?
    What about the wiring; output of the dynamo looks like. Do I need to buy some extra cables?
    Thanks for your helpfulness
    so from the hub, one wire is switched to light or plug, via a SPDT switch, the other wires is just joined to together...K
  1. Replies: 4
    Last Post: 08-08-2013, 09:04 PM
  2. Shimano Revo shifters
    By r1Gel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2013, 10:29 PM
  3. 2013 Exposure Diablo Mk4 Review, also includes MaxX-D and Exposure accessories
    By digitalhippie13 in forum Lights and Night Riding
    Last Post: 02-01-2013, 09:57 PM
  4. Dynamo light + dynamo GPS (or phone) charging. Bye-bye batteries?
    By robdeanhove in forum Lights DIY - Do It Yourself
    Last Post: 11-04-2012, 02:38 AM
  5. revo lights
    By sdy284 in forum General Discussion
    Last Post: 09-11-2011, 05:38 PM
