Hi all,
I recently bought Magicshine clone light clone from DX. Unfortunately battery pack that came in set is only 4400mAh which is not enough for my needs (only 2.5h running time).
httx://dx.com/p/ssc-p7-3-mode-900-lumen-led-headlamp-bike-light-set-4-18650-50947
(just change x with p on the beginning of link)
Tech:
Emitter Brand/Type: Seoul Semiconductors SSC
Emitter BIN: SSC P7 LED
Color BIN: White
Total Emitters: 1
Battery Configurations: 4 x 18650 (included)
Voltage Input: 8.4V
Switch Type: Clicky (Clickie)
Switch Location: Tailcap (Tail-cap)
Modes: 3
Mode Memory: Yes
Mode Arrangement: Hi > Low > Fast Strobe
Circuitry: Digital Regulated 2800mA Current Output
Brightness: 900 lumens maximum brightness (manufactuer rated)
Runtime: Hi:3~4 hours (manufactuer rated)
Lens: Coated Glass Lens
Reflector: Aluminum Textured/OP
Accessories Included: 1x Head strap, 2x rubber ring, 1x 100~240V power adapter (US plug), 1x battery holder, 1x Chinese/English manual
I came to idea to modify battery pack in a way to remove 4x18650 battery (1100mAh each) and to install new 4 x 18650, but with 2500mAh or more. I dont know is it possible to replace buttery just like that, or is there something else that its need to be done. I know that in battery pack beside battery is some electronic...(?)
If I upgrade battery pack in that way and if I get 10000mAh instead 4400mAh could I expect to get also double running time - from 2.5h to 5h?
Thank's in advance! :thumbsup:
Tech:
Color BIN: White
Total Emitters: 1
Voltage Input: 8.4V
Modes: 3
Mode Memory: Yes
