    Bigger is better!
    May 2005
    Protection circuit in MS batterypack?
    Does anyone know if the MS batterypack has built-in protection for over-discharge?
    They sell the packs separately on DX (sku 32756), and I'm thinking about using them with a DIY light, possibly without protection in the driver..
    Bigger is better!
    May 2005
    Several of the posts here
    http://www.dealextreme.com/forums/forums.dx/forum.32756
    say that the pack has a protection PCB for the whole pack. Can someone give a 100% confirmation of this?
    Quote Originally Posted by langen
    Battery has protection, yes.
    Four unprotected 18650 cells in 2 parallel 2 series (2P2S) configuration with a separate protection PCB.
    The PCB has three inputs (Battery +ve, Battery -ve & the mid point) and has two outputs (+ve and -ve to the light head).
    Provides under-voltage and over-current potection (possibly temperature protection also).
    The battery packs usually need sealing (dip or cling wrap) if used in the wet. Water is usually what kills the packs outright.
    HTH.
