Results 1 to 5 of 5
    Reputation: craigstr's Avatar
    Sep 2003
    Problem with Cadence and the Edge 305
    I have an Edge 305 with cadence. It worked fine for a few months then started cutting out. I changed the battery in the sensor and it still didnt work. I rescanned for the cadence and still nothing. Then one day it will work, the next it wont. Sensor is aligned with magent perfectly. Any ideas??
    trail rat
    Reputation: slocaus's Avatar
    What did Garmin say when you called them?
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    How's the gap between the magnet and sensor doing? I found I occasionally nudge my sensor with my heel while riding and as a result, I had a similar issue for a little bit.
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    Flyin Pig
    Reputation: IvanLasston's Avatar
    Also did you update your software. I had intermittent connections with my forerunner 305 and the cadence sensor. Updated the software and it connects fine now. Edge 305 has a software update on May 4.
    http://www8.garmin.com/support/colle...t=010-00447-00
    As it was stated the gap was also an issue. I had the problem of the sensor moving around. I also had a second problem in that I had a dual suspension mountain bike. When I lined everything up I wasn't sitting on the bike. I didn't account for sag so the magnet was off. Point being, sit on the bike and have a friend move the sensor around.
    GeoMan
    Reputation: GEOMAN's Avatar
    Quote Originally Posted by IvanLasston
    Great feedback! This may help others.
    Thanks and glad you got it working.
    GeoMan
    We Ride!
    www.geomangear.com
