Results 1 to 3 of 3
    Bonking ... not feelin' well Polar CS200cad Problem
    I both recently Polar CS200cad, and everything is working great, except the cadence.
    Cadence is sometimes working ok for a 5 minutes, and then is gone for 5 minuets.
    Ther is no electronic interference around.
    Manual says max 80cm, and my is set on 70cm.
    If I bring it closer it works ok, bat is not possible to mount it closer. I have Specialized FSR Expert and 70cm is the min. I can mount the unit and sensor.
    Anyone have any solution for this problem.
    Reputation: pitmang1's Avatar
    I have had the same problem, but I still haven't figured out a fix. I'm thinking that I might mount the computer on the top tube and see if that helps. I'll let you know. Maybe a new battery will help.
    _
    _
    Beware the man who has just one gear. He may know how to use it.
    I had the same idea, but I don't like to have the unit on the top tube, and it should work within the range of 80cm.
    The battery is not replaceable. You have to buy complete sensor, and mine is new.
