Results 1 to 16 of 16
    Bonking ... not feelin' well Please help My light stopped working
    Hi all,
    I bought a troutie 6XPG light kit awhile ago now(maybe 12 months) its been working great. but for some stupid reason when i turned it off the other day it wont come back on. i pulled it down and tested all connections and they all work. 16v from battery 2.3v across switch. all LEDs light up when multimeter is on them. do you think my driver may have died?
    I did notice when it was open with power supplied a small amount of smoke appeared and the driver is getting very hot. I have been using this light for 4 hour night rides on high the whole time with no issues. how do i check if power is going to the LEDS?
    Please help im scared of the dark.
    Thanks Josh
    After closer inspection, it must have gotten very hot, a resister has desoldered itself. Ill upload a pic soon so someone can tell me if i should reconnect it. George??????
    Here are the pictures of the missing bit
    Attached Thumbnails Attached Thumbnails Please help My light stopped working-p8220094.jpg
    sorry about the big pictures. i forgot to resize them
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Based on the silk screened D1 on the board, I'd say that's a diode that has detached. I'm betting that's the diode for reverse polarity protection, so with it missing from the board you've got an open circuit between the battery and the driver.
    The obvious question is why did it detach? I notice the Maxflex is just floating around in the case.. it should be glued in place with thermal epoxy as it needs the case as a heatsink to prevent the driver overheating. So if you didn't pull the driver lose the n perhaps the driver overheated enough to cause the solder holding D1 to let go? hmmmm...
    Interesting thread.
    George should have a good idea of what happened I bet.
    Isn't the reflow solder temp around 400F. Can't imagaine the maxflex getting that hot from currrent and not having one of more of the board components shut down.
    Sort of remember George mentioning some sort of switcher that will shut down at higher temps.
    Reputation: bwack's Avatar
    Diodes overheat when if current is high, OR it has failed to operate correctly.
    A failed switching transistor (U2?) can cause high currents.
    You may have had an short-circuit to the enclosure. It is floating afterall..Inspect the rear side for any burns.
    Luckily the diode worked like a fuse.
    Edit: I was wrong with the failed transistor. I was thinking of a Buck-driver, but this is a boost driver. see Georges answer below.
    Quote Originally Posted by bwack
    Agreed, and looking closely at the picture of the diode I believe I see a crack in the casing which would tend to support that it saw very high current and probably got red hot before it detached. A short to ground is the most likely cause.
    i pulled the driver out to see whats going on. is was glued in place with thermal adhesive and i also had some silicone to help hold it where it should be. Looks like i'm up for a new driver then?
    A waste of time it is is
    Reputation: emu26's Avatar
    Did you have thermal protection set?
    not sure. I don't remember what settings I had when I first built the light
    The diode is the schottky diode feeding forward from the inductor in the switcher core. Being a boost driver, the schottky is in direct series to the LED load.
    For the diode to have melted the solder I'd lay 100 to 1 odds that you had a short circuit in the LED array to ground (chaffed wiring etc etc etc).
    Basically being a boost driver there is a direct DC path from the battery through
    a) reverse polarity FET
    b) inductor
    c) schottky diode
    d) current sense resistors
    to the LED load.
    With a short at the output and given the low resistance of a) b) and d) most of the power dissipation will occur in the c) the schottky diode and it would have melted off first and acted as a fuse.
    I've had a few folk report melted off diodes due to 'momentary' shorts on the output...
    Unfortunately with the diode out of circuit, the switcher IC would have bit the big one, so replacing the diode will not 'repair' things.
    So,. end result, you have a dead maxflex due to a short in the output section of your light system.
    cheers,
    george.
    Quote Originally Posted by georges80
    b) inductor
    c) schottky diode
    to the LED load.
    cheers,
    george.
    Not what i wanted to here. but thanks George for letting me know. Should i just order another one from Cutter? at $60 i hope it doesn't happen again.
    Thanks Josh
    Quote Originally Posted by Joshp82
    Thanks Josh
    You'll need a new one either from Cutter or directly from taskled.com. But, I wouldn't just replace it and hope for the best. That could end up being rather expensive if you keep blowing drivers. You need to investigate and figure out the root cause of the problem.
    From what i could see when the driver was out, it wasn't sitting 100% flat on the heat sink and I'm not sure what temp i had the thermal cut off set to or if i even had 1 set. I'll just have to make sure everything is perfect next time. is an expensive lesson but 1 i will learn from.
    Just looking at the pictures there is a lot of bare wire sticking out of both the ground and the led posative .
    and as George said his odds were a short from the leds to ground then could it be possible for a stray strand to have shorted and done the damage
    I go away at the end of the week and the offer is still there
