Results 1 to 2 of 2
    planning xml double. have questions
    i had a plan to make a double xpg light and i had all things figured and ordered. now
    im planning to make it a double xml instead housed inside an alu profile with the inner dimesions of 20*36mm and driven by 7.2V battery but i have questions .
    what driver/drivers should i use ?
    i have some drivesr kicking around 2* 1200ma 3-18v buck drivers
    but it doesnt feel right to run them in paralel thoughts?
    a budget sugestion
    and a ultimate solution sugestion
    what optics do you recommend?
    im thinking for bar mount i have reginas that was intended for the xpgs.
    is there something better that will fit my intended housing without to much modification?
    Cheap driver: 8*7135 (2.8A)
    The regina work fine for bar or helmet in a 2x.
