Panasonic 3100 mAh on dx
Printable View
  • 12-04-2012
    Ofroad'bent
    Are these the real deal?
    Barb was using one of my 1S2P battery packs on the weekend in a night orienteering race, and she said the light (Single XM-L, L-flex set on multi-level with max at 3000ma) wouldn't work on level 5 at all and started to give her a warning flash after an hour on level 4.
    I wonder if the battery pack just couldn't handle 3000 ma, or if the protection circuit in the battery pack cut in.
    I think I may need to build her another pack with more capacity, and hopefully a more generous internal protection chip. Think these will do the trick, if they are genuine?
    Genuine Panasonic 18650 3100mAh Rechargeable Battery with Protection Board - Green (Pair) - Free Shipping - DealExtreme
  • 12-04-2012
    OverTheHill
    I think I've seen some recent discussion about this on CPF and/or BLF but can't remember what the general consensus was. I think it was on one of the threads about "Best 18650 to Buy" or something like that.
    I'll have a root around later and see if I can find it again.
  • 12-04-2012
    OverTheHill
    I just did a quick search on CPF for "Panasonic DX" and quite a few threads came up.
    One of the things I did remember was that Panasonic only produce unprotected cells. The protection circuits are put on by someone else and the relatively cheap protected cells on DX may have genuine Panasonic unprotected cells in them but the PCs are crap (apparently).
    I guess you get what you pay for. I did see a comment from one poster on a thread that he had tested one of the DX 3100 mAh unprotected cells against a known pukka Panasonic cell and it was genuine.
    Hope that helps.
  • 12-04-2012
    Ofroad'bent
    So, what was the "Official CPF Best High Capacity Battery" to buy?
  • 12-04-2012
    [jsl]
    I have four of the unprotected Panasonic 3.1Ah cells from DX. I did some capacity measurements and they are pretty close to 3.1Ah, don't remember the exact results. However, I did the measurements with brand new cells that had been charged only once and twice. The capacity was slightly higher after second charge. I discharged them individually at 1A.
  • 12-04-2012
    pucked up
    Here is a write up on BudgetLightForum about protected Panasonics 3100ma cells.
  • 12-04-2012
    Ofroad'bent
    They look pretty good.
    OK, now how about some decent 3400 mah cells? Anyone got a suggestion?
    Safer to buy unprotected and protect them myself?
  • 12-04-2012
    HEY HEY ITS HENDO
    suggestions?, go 3P
  • 12-05-2012
    Toaster79
    Here is the 2012 battery test on CPF.
  • 12-05-2012
    BUGY
    1. There is no 3400Mah cells! Only 3100, from panasonic.
    2. If you build a pack, then you need Unprotected cells :nono: and then put a protection board on the hole pack.
  • 12-05-2012
    Toaster79
    Now you're talking rubbish!
    Panasonic NCR18650B is a 3400mAh rated cell.
    Using protected cells in a pack means, they are all protected individually, no matter how you wire them, so common PCB is not needed if you use charger that can balance your cells and of course you wire a balance harness to the pack. Wiring cells first, than adding PCB is okay too, but there is nothing wrong with using protected cells without common PCB. Biggest problem of the packs using unprotected cells and PCB is, the PCB is not capable of balancing during recharge.
  • 12-05-2012
    BUGY
    :eekster: I am out of date. Last time I build myself a 2S2P pack the 3100 wore the hist capacity cells.
    Yes you can build a pack whit protected cells but way? They are more expensive and this is not the proper way to go. Sorry but my english ist sufficient to explain properly :madman: Search this topic.
  • 12-05-2012
    mattthemuppet
    I'd buy the plain NCR18650B if you can find them (they were in short supply last time I looked) and put your own PCB on there. If you don't mind giving up a few 100mAh, the NCR18650A are fine and you can find them from a bunch of reputable sellers. Chinaqualitygoods has decent prices and the 2900mAh cell I bought from them checked out, or you can buy from Orbtronic in the US which has decent prices and also checked out.
    Spend some time on the BLF batteries forum and you should pick up some more places to order from. I think a user called KumaBear was bringing in a whole host of different batteries, but I haven't read any feedback reports on them yet. I see no reason to play the DX lottery when there are so many other options. They lost my trust a long time ago.
    BTW, what were the cells that couldn't provide the juice?
  • 12-05-2012
    Ofroad'bent
    I will probably see if Ktronik still has his nice protection boards.
    After a lot of tinkering, something seems wonky with Barb's light, not the battery. The same battery runs all my other lights fine, but we get a Low Voltage warning on level 5 on hers after about 30 seconds, regardless of battery pack.
    I've been e-mailing George at TaskLED, and it sounds like I need to test the voltage across the board at the 3000ma setting and play with the low voltage warning on that light.
  • 12-06-2012
    adrenalnjunky
    I've got 2 pair of the protected cells on the way - ordered a week ago - hope to see them in another week or so. I'll report the typical discharge/charge info.
  • 12-07-2012
    [jsl]
    Could it be that the threshold for low voltage is set so high that when at 3A, the battery voltage sags due to high current draw and triggers the low voltage warning?
  • 12-07-2012
    Ofroad'bent
    That was my thought. I opened the light and measured the voltage.
    Level 1-3 = 3.9v
    Level 5= 3.48 v
    There's definitely some voltage sag. Could be the battery cells (Samsung 2600mah), could be cheapo protection circuit, but the main thing I noticed is that the l-flex had pulled away from the housing, so wasn't getting proper heat sinking.
    I replaced the thermal tape, re soldered the connections for good measure, and it seems OK now.
  • 12-07-2012
    Ofroad'bent
    I will still consider building a higher capacity battery pack.
    Interested to know if the PCB on these eBay batteries is decent:
    2pcs Protected Panasonic 18650 NCR18650B Rechargeable battery 3400mAh With PCB
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...p:en#ht_2794wt
    They claim :"The PCB is made of Seiko stainless steel protection plate, maximum power voltage is 4.2V, the minimum voltage of 2.5V,the PCB is using 2 MOSFET version,is different with other sellers with the single MOSFET only."
    It sure would be simpler than ordering PCMs from Ktronik and wiring up unprotected cells, even though I know ktronic's boards are excellent.
  • 12-07-2012
    [jsl]
    Since you are using 1S2P configuration and LFlex, I would simply forget individual cell protection. Configure the driver's thresholds for medium, low and cut-off to some suitable values and there should be no real risk of with ruining the cells.
  • 12-07-2012
    mattthemuppet
    personally I wouldn't touch 'em with a pole, especially that that price. It doesn't matter what they say about the PCB, there's no guarantee that it will actually be that (or even a real PCB, believe it or not). Plus they don't specify the overcurrent spec or anything like that. eBay + 18650 + China = bad.
    I would trust Orbtronic (or it's eBay shop) or CNqualitygoods. I've bought and tested batteries from both places. Plenty of people have had successful orders with KumaBear on BLF too. Prices seem pretty reasonable - $12.50 for protected and $10.50 for unprotected NCR18650B. I'd be more likely to trust some random person off BLF than I would a Chinese eBay seller :)
  • 12-07-2012
    HEY HEY ITS HENDO
    http://www.hobbyking.com
    i would go this route....
  • 12-07-2012
    mattthemuppet
    more weight for less capacity though, which is more of an issue on the helmet that the bars :)
  • 12-07-2012
    adrenalnjunky
    I'm not going to run a LiPo battery for these - mainly cause I'm afraid of the damn things. I had one for a RC plane swell up on me just sitting on the bench with what was probably a 85% remaining charge.
    Anything you have to charge in a special container in case of fire isn't something I want to be carrying on my helmet or in my camelbak.
  • 12-07-2012
    Ofroad'bent
    Not all my friends have smart chargers. For myself I can use unprotected batteries.
  • 01-13-2013
    Ofroad'bent
    I got some of the unprotected 3400maH Panasonics.
    I tried them in a friend's protected 1S2p holder, but couldn't get more than 2500 maH out of them.
    I suspect it's something to do with a crummy PCM in the holder.
    I got 2550 out of one cell tested directly without PCM. Still not what I expected.
    My Accucell charger was set to discharge them to 3.0v.
    I seem to remember reading that these cells have more capacity down to lower voltages without damage. Maybe I should have tested them to lower voltage.
    This will be a PITA if I have to reconfigure my lights voltage cut-off, and suspect the PCMs I ordered from ktronic will cut off at 3v anyway.
    Any thoughts?
  • 01-13-2013
    Ofroad'bent
    Here are the batteries.
    2pcs Panasonic 18650 NCR18650B 3400mAh Rechargeable battery Free Shipping | eBay
    Charging voltage 4.2v
    Nominal voltage 3.6v
    Cut-off voltage 2.5v
    Capacity (0.2C, 2.5v discharge) 3400maH
  • 01-13-2013
    iperov
    I bought hundred oem NCR18650A from taobao 6.64$ incl ship, and created ebike battery.
    So DX is reseller.
  • 01-13-2013
    HEY HEY ITS HENDO
    Any thoughts?
    what was your discharge rate?
    are you expecting too much?
  • 01-13-2013
    Ofroad'bent
    Discharge at 1A.
    I was expecting 6800 maH, not 2500 from 1S2P
  • 01-13-2013
    HEY HEY ITS HENDO
    Any thoughts?
    ahh not so good then, ...but this statement threw me ^
  • 01-13-2013
    adrenalnjunky
    I just got battery tabs welded onto my DX protected 3100 Pannys yesterday - I've got the 1st one running through a discharge/recharge cycle on my Accucell-6 now. I'll post my results.
    Anyone know a way to get the Accucell to discharge to less than 3.0v/cell? Not that I'd really want to on a regular basis.
  • 01-13-2013
    HEY HEY ITS HENDO
    set it to Pb or ni-MH and adjust the cut off
  • 01-13-2013
    mattthemuppet
    sorry to hear about that ofroad. So was the 2500mAh per cell or per 1S2P pack? First is a rewrapped cell (Sanyo 2600?), second is complete junk.
    There's not really much point discharging below 3V as there's next to know capacity left below there (about 10% left under 3.2V @ <0.5C discharge).
    Other than Orbtronic (US based business that also sells on eBay), I really really REALLY would advise against buying 18650 cells off eBay, even more so from China. There are so many other options, that it's just not worth the waste of time, even if you get your money back from Paypal.
  • 01-13-2013
    mattthemuppet
    that's a truly insane amount of battery soldering! It would almost be worth buying a battery spot welding set up for doing that many
  • 01-13-2013
    Ofroad'bent
    As suspected, there was a problem with the Protected holder. Just found that one side of the holder is bad, so only 1 cell was running. Still low capacity for even one cell.
    The cells sure look like genuine Panasonic 18650bs.
    Should have taken Matt's advice.
  • 01-13-2013
    iperov
    I bought new 255 pcs from taobao by $3.3 each + taobao agent % + about $100 shipping
    this will really insane xD I planning 48V 40ah ebike battery weighting 8-9kg.
  • 01-13-2013
    borrower
    Out of curiosity, do the labels have any overprinting like you see on the (-) end of the picture at the top of this review: Test / Review: Panasonic NCR18650B 3400mAh (Green) | BudgetLightForum.com ?
    Part of the reason I ask is that there are fake wrappers available on taobao for what seems like every brand of battery (including some panasonics, though I haven't seen the 3400s).
  • 01-13-2013
    troutie-mtb
    We all know the old addage of if it looks too good to be true it probably is .
    has any one tried weighing cells and comparing them to lesser AH cells
    I did with some 14.8 volt 4.4 packs and a 5.2ah pack because I had plastidipped them all and forgot to mark the 5.2 pack
    it was heavier than the 4.4s
    I ahve it from Smudge who makes his living from batteries that the 3.4 ah cells are a rarity
    and unreliable so he rarly specs them in stuff.
  • 01-13-2013
    Ofroad'bent
    Yes, there is the overprinting. Does that imply fake or genuine?
  • 01-13-2013
    Ofroad'bent
    Guess I'll return the wimpy cells. Orbtronic and Kumabear don't ship outside US. Is CNquality kosher?
  • 01-13-2013
    borrower
    I've got no expertise here, but I'd imagine that the overprinting is a good sign... though I suppose it's possible that if it was a fake label, they could have added in the appearance of overprinting.
  • 01-13-2013
    mattthemuppet
    the one cell (NCR18650) I got from them was legit, although that doesn't say anything about any other models. Their CS is kinda crappy though - Intl.Outdoor is better and the owner does a mahoosive amount of battery tests on BLF.
  • 01-14-2013
    Ofroad'bent
    Link to Intn'l Outdoor please?
  • 01-14-2013
    [jsl]
    Google is your friend: Led Flashlight-International Outdoor Store ;)
  • 01-14-2013
    Ofroad'bent
    OK, ordered a pair of protected 3400s from Intl Outdoor.
    When I get them I'll test 'em and report back.
  • 01-14-2013
    adrenalnjunky
    FYI - and I don't know enough to be dangerous, but checking the review of the protected DX3100's on BLF : Test / Review: NCR18650A protected (Green) | BudgetLightForum.com
    I discharged my cells down to 3v and recharged getting 2734 and 2831ma out of each cell I charged yesterday. That approximates the graph of testing on BLF, so I'm fairly certain I got what I paid for. I ordered and received mine from DX right before Christmas.
    The local BatteriesPlus welded tabs on to all 4 of mine for no charge (they even used thier own tabs!) - I was surprised, as I'm not a regular customer there. I might have to talk to them next time I buy cells though, as the guy behind the counter says he can get 18650's like those. We didn't discuss price. I was impressed at the local franchise's customer service, and I'll go back there for other stuff.
  • 01-14-2013
    Ofroad'bent
    Well, mine weren't a ton lower, but should have been in the 3200 range, not 2550.
  • 01-14-2013
    adrenalnjunky
    Oh yeah - I agree that something's up on yours. sounds more like you've got 2700-2900mah cells. If you can't return them - I'd personally pull the wrappers on one just to see if you can find any other markings.
    Is it possible there's a really high amount of resistance in the internal wiring of the holders being used that might be causing the sensing in your charger some grief? I'm just thinking out loud here.
  • 01-14-2013
    Ofroad'bent
    Nah, I tested some unprotected Digikey holders too.
  • 01-15-2013
    Ofroad'bent
    Well, the good news is I just got a full refund from the vendor on eBay. Didn't even ask me to return the cells yet. He still claims they are genuine, and perhaps my testing isn't accurate. He feels they'll run longer in the lights, but was good enough to refund so I have no complaints.
  • 01-15-2013
    rschultz101
    comment,...
    new cells need to be cycled , 2-3 up to 5 times to get full capacity
    clones, etc, HK, would skip it. they are good at making labels,...
    panas,
    high capacity ?! yes, it's exiting . heard, they loose about 200-300mah in less than 50 cycles.
    if you got room, (more weight), or need current, stick to 26650's
    MS charger, don't charge them fully, cheap charger 6-8% less charge
  • 01-16-2013
    MtbMacgyver
    Originally Posted by rschultz101 View Post
    comment,...
    I see people say this fairly often, but it's counter to what I've read in the technical literature from li-ion battery manufacturers. The few times I've measured light runtime on the very first cycle after building a pack, I haven't seen any increase after 2-3 cycles. I'm curious where this recommendation originates? It is true for nickle based batteries.
  • 01-16-2013
    rschultz101
    usually on quality cells, cycling is part of conditioning and testing.
    cheaper mfg's skip on everything.
    these new type cells, contain Nickel.
    for packs, it is good to cycle / balance , measure, to ensure it's ok.
  • 01-16-2013
    MtbMacgyver
    Here's the official datasheet from Panasonic for this specific cell. The cycle number graph shows the capacity starting from 0 cycles with the highest capacity and falls after that.
    http://industrial.panasonic.com/www-...A4000CE254.pdf
  • 02-02-2013
    Ofroad'bent
    Finally got my PCMs from Kerry.
    The cells are testing 2600-2750 each, not bad but definitely short of the claimed 3400. No complaints with a full refund.
    The other hopefully more legit ones haven't arrived yet.
  • 02-02-2013
    borrower
    You'll get a different number, depending on the discharge rate... of course, the manufacturers make it an optimal one for their benefit. Plus, the 3400 is tested down to 2.5 volts IIRC, so you're losing some there.
    Last time I bought batteries, I figured that they were a bit better than 3100s for not much more coin, so went for it.
  • 02-04-2013
    mattthemuppet
    I doubt that you're losing much more that 5%, if that, by discharging down to 3V instead of 2.5V. HKJ did a bunch of tests for remaining capacity and found that there was only ~10% left below 3.2V. I've capacity tested NCR18650 and NCR18650A cells on my admittedly uncalibrated and probably not terribly accurate Thunder AC6 and they check out about right (2850 and 3050-3100, respectively). My guess is that the ones Ofroad'bent got were rewrapped Sanyos, which are still decent cells, just cheaper and lower capacity than NCR18650A/B.
  • 02-06-2013
    adrenalnjunky
    are those numbers after you add the 5 or 10% you mention, or those are the numbers you get when charging after a discharge down to 3v?
  • 02-06-2013
    mattthemuppet
    the capacity figures are for a 1A discharge from 4.2V to 3V. If you want capacity down to 2.5V, add 5% at most to those figures. Don't forget though that this is with a hobby charger (ie. not calibrated) and for only 3 cells, so hardly what I'd call a scientific experiment :)
