Results 1 to 8 of 8
    Dec 2009
    OT: LED's for car interior - electrical question
    Sorry to post this here, but after building several bike lights from info on this forum, I knew that the electronics wizards here could help answer my question.
    I've replaced my car's interior lighting with LED's (looks hot!) and a well known issue is the bulbs glow very faintly even when "off". There is some amount of current going through the system at all times I guess but not enough to light the original incandescent bulbs.
    To fix the issue you can wire in a resistor parallel to the bulb. For testing I've used 1/4 watt and 1/2 watt at both 100 ohm and 220 ohm only b/c I had these left over from bike light projects. All sizes tried do get rid of the unwanted glow.
    My question is, what wattage resistor do you guys recommend for this application? I'm starting to worry that 1/4 watt, or even 1/2 watt, is too small for this application.
    recognize the slowness
    Reputation: jbflyfshr's Avatar
    What did you use for the builds? I have mulled doing the same thing to my cars for a while. Would really like more light in the trunk/hood areas especially...
    JB
    "mountain biking and flyfishing, what more do you want?" - Yeah, I said it
    Joe, we need to know how the leds are wired, what kind of vehicle. Some vehicles have switched hot and some are switched ground. We can fix this! James
    Dec 2009
    It's not really a "build", I used some off-the-shelf leds.
    I used these for the dome and floor lighting - very bright (by dome-light standards that is!) - in blue:
    http://store.ijdmtoy.com/Luxer1-12-L...anel_sku53.htm
    And these for the map lights (not as bright but better than stock and better color - used cool white):
    http://store.ijdmtoy.com/SMD-LED-Map..._d42_sku23.htm
    Some lights are switched on in pairs and only needed 1 resistor per pair, the map lights can be switched on individually and needed 1 resistor per light.
    Thanks guys!
    I have two of these in my trunk. Not the round ones, but the longer ones. Nice even light that lights up the whole trunk. They're 12v ready too, no resistors needed.
    Dec 2009
    The resistors are only needed for applications where the lights glow dimly when "off". The lights work just fine as-is without the resistors.
    So, anyone have any idea what wattage is recommended here?
    can you find out what sort of current they draw when off? Then all you need to do is current squared x Ohms = power. As long as the power rating of the resistor is comfortably (25%? 50%?) than the power dissipation, then you're golden.
    Dirt Deviant
    Reputation: savagemann's Avatar
    I'm not really sure what the issue is, but I picked up some of these to modify the lights in my shuttle vehicle/daily commuter van.
    http://www.dealextreme.com/p/mr16-1-...0v-input-13557
    Look, whatever happens, don't fight the mountain.
