Results 1 to 3 of 3
    Sep 2012
    Optics. Using an xre lens with an xml.
    I wanted to use a 15mm lens with a xml u2, but all i can find are 20mm xml lens. So if i use a 15mm xre lens, will it work? or will it melt or throw some odd beam pattern?
    This is my first light build attempt and i dont really know what im doing.
    Are there any 15mm xml lens i could use?
    May 2005
    I don't think I have ever seen anything smaller than 20 mm for an XML. If the XRE optic fits the XML dome it may work to some extent. Not likely to be a great beam as there is a huge difference in die size between those two LEDs.
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    The XRE led is very similar in dome size to the XML. I used ledil square XRE optics in my twin XML but needed to do grind down the optic holder to match the focal distance to the XRE optic-led dome. You can do this easily by looking at the CAD drawings of the 2 leds and working out the difference from the led pcb to the top of the dome. From memory it was only a mm or so
    Cheers
  1. XML optics
    By joebreez in forum Lights DIY - Do It Yourself
    Last Post: 02-13-2012, 11:43 AM
  2. XML optics?
    Last Post: 11-02-2011, 07:35 AM
  3. XM-L Optics?
    By BlueMoon100 in forum Lights DIY - Do It Yourself
    Last Post: 09-30-2011, 02:41 PM
  4. Century Optics Ultra Fisheye MKII lens
    By antiherohio in forum Videos and POV Cameras
    Last Post: 02-22-2011, 04:40 PM
  5. Magicshine flood lens, new optics
    By rschultz101 in forum Lights and Night Riding
    Last Post: 02-09-2011, 08:21 PM
