    Bigger is better!
    May 2005
    OK to have drivers in parallell?
    Even if they drive different number of LEDs?
    E.g. one Buckpuck driving 2 x XP-Gs in series, and one Buckpuck driving 3 x XP-Gs in series, and both Buckpucks are wired in parallell, driven from the same 14,8V battery.
    Come see me after class
    Dec 2005
    if they're wired in parallel, it should not be an issue.
    Bigger is better!
    May 2005
    That's what I think as well.
    But it's OK to be sure, to avoid frying a driver and X number of LEDs...
    May 2005
    Just to make this more clear for less experienced builders out there...
    In the scenario of the OP, it is OK to wire the input (battery) connections in parallel to a common battery. It is NOT OK to connect the output (LED) wiring in parallel because of the unbalanced (2S and 3S) LED strings.
