Results 1 to 20 of 20
    Noob question/Suggest a simple project please
    I know I can't afford to buy outright what I'd like, so I figured I better learn how to build. Couple of questions, using the K.I.S.S. principle, would I be better off gutting a cheap light for the housing or building something from Alu. tubing? I figure there's a good chance I will screw this first (and maybe more) attempt up. So simplicity of build is first and foremost. I bought a couple lights made by a member here (Alu. tube type) and was thinking I could tear one apart and use it as a test bed and only have to replace the guts. Please help a rookie get his feet wet and thanks for reading my post.
    Dirt Deviant
    Reputation: savagemann's Avatar
    I would do up a Citizen Kane style light. Super simple for a first build.
    Here is a link to my first bike light build..........
    Finished first build CK style BEAMSHOTS ADDED!
    here is a link to the original CK thread...........
    Easy DIY
    I need to update my build thread with a couple pics of how I ended up making my mount.
    Long story short I used a spare magicshine base plate and my MS helmet mount.
    I would personally use the cateye mount like CK did.
    Look, whatever happens, don't fight the mountain.
    Quote Originally Posted by savagemann
    Easy DIY
    Thanks for the reply. Hey are you and me cousins? Lol.
    I made a nice helmet light loosely based on this thread. The Amoeba and the Copperhead
    It was pretty cheap, and easy to make. I don't have time to make a "how to" right now but I'd be happy to help if you want more info.
    KBARK, I may take you up on the offer of help. Thanks.
    Dirt Deviant
    Quote Originally Posted by SAVAGESAM
    Holy crap, I think we are!!!!
    Here is the helmet light that I built.
    2 XPGs driven by a buck puck and two 18650's.
    A waste of time it is is
    Reputation: emu26's Avatar
    [QUOTE=SAVAGESAM]hEY ARE YOU AND ME COUSINS?[QUOTE]
    and here I was thinking savagemann was the son of SAM
    Dirt Deviant
    Quote Originally Posted by emu26
    Haha!!!
    Nice setup KBARK. Looks like a straight forward build.
    KBARK, when you have time will you put up what I'd need to do this? No hurry. Thank you for your offer to help.
    Here are the parts I used to make that little helmet light.
    2 XPGs from LedSupply http://ledsupply.com/creexpg-w139.php
    2 Optics (don't forget the holders) http://ledsupply.com/10003.php
    1 BuckPuck. http://ledsupply.com/03023-d-n-1000.php
    Artic Alumina http://ledsupply.com/aata-5g.php
    The housing is made from 1x1 inch aluminum tube. Depending on the wall thickness you find you may need larger than 1x1inch.
    The copper end caps I got from Lowes and glued them on with JB Weld.
    2 x 3/4inch copper end caps http://www.lowes.com/pd_21664-76063-...e|0%26page%3D2
    Pick up some 1 inch plastic end caps that are in the hardware section also.
    The power connectors came from Radioshack.
    I have some Alu. round tubing do you think I could just use that and build everything inside it? I bought a used set from a member here and they work pretty good. I have two of them (one spot, one flood) I was thinking of taking one apart and trying to go from there. I'm just not sure of myself but keep thinking I can't learn to swim without getting wet lol.
    If you have round tube you might want to look at a dinotte style light. DIY Dinotte Style
    Quote Originally Posted by KBARK
    KBARK, thank you. That is the type that I bought two of from a member here (I won't mention his name because I don't have permission) Anyway I have some excess tubing and I'm going to give it a shot. If I can stuck, would you give me a kick/advice/help?
    Reputation: Ofroad'bent's Avatar
    If your tubing's fat enough -1" diameter- you could fit an XM-L and L-flex in there. Add a momentary switch and a 3.7v battery and you're done.
    What ever you decide to build, you can always find help on this forum. It's one of the most friendly and helpful groups around.
    Ofroadbent, I would use a "Momentary" switch? I thought I needed some sort of "Clicky" type?.....Thanks KBARK, the post above should of said, if I GET stuck, not can stuck.
    Quote Originally Posted by Ofroad'bent
    What is an L-flex? Do you mean everything would fit in the tube or just the XML and L-flex? Thanks.
    The L-flex is a driver made by George at Taskled for running one XM-L from 3.7v. It needs a momentary switch to operate.
    It's about 20mm in diameter, (Corrected posting) so you could fit it in your tube along with a Regina or Dx reflector I think. It has multiple brightness levels up to about 900 lumens.
    I got the switch, driver, LED and reflector to fit in 1" square tubing.
    Heck, you could use a longer tube and even stuff a single battery in there.
    You can check out my version of Mattthemuppet's design at:
    XM-L Sled Light- Mattthemuppet-style.
    Dirt Deviant
    Correction on the diameter.....it is more like 20mm. Mine all measured around 19.8mm
