    Reputation: Nocturnus's Avatar
    Mar 2005
    Night Rover retrofit.
    Has anyone done an LED setup in a Night-Rover body? I picked up one for cheap and was thinking it'd do well for a housing (maybe).
    Do you mean the Cygolite Night Rover with the plastic body? I am not a DIYer, but I know the body must be metal to dissipate heat.
    Bike Geek
    Reputation: norcalruckus's Avatar
    May 2005
    Cool-blue Rhythm thoughts?
    So where do you get led lights to try this?
    RIP AL DAVIS
    txn
    txn is offline
    Reputation: txn's Avatar
    2 things to keep in mind with this.
    1. Plastic body will probably melt
    2. 6V battery (if yours is like mine) will require a boost regulator to run two LEDs in series. I don't know what your efficiency will be like, but with a 5Ah battery it may not be a big issue.
    If you want to BYO LED light you could do one of the DIY Dinotte ones like I did fairly inexpensively. I even designed mine to be able to use my Night Rover battery.
