Results 1 to 11 of 11
    New Lighthead needs a 39x1mm O-ring seal!!
    I designed a new Lighthead around my existing platform to convert it from 6xXRE to the 7up XPG/E light engine!
    Therefore i need a O-ring seal with 39mm diameter and 1mm cross diameter
    Bad thing, i can't find anywhere such an O-ring
    Any ideas or can someone supply me such an o-ring?
    Attached Thumbnails Attached Thumbnails New Lighthead needs a 39x1mm O-ring seal!!-lampenkopf-variante-2_1.jpg
    ..just ride...
    Nov 2008
    can you go to 1.5mm , http://www.polymax.co.uk sell them........
    alternatively you could perhaps make one from 1mm cord?
    Toby
    yes 1,5mm would be easy, but then the o-ring would be forced into the beam, because i cannot increase the housings inner diameter....
    ..just ride...
    May 2005
    Maybe get 2 smaller ones and splice them into the size you need. Superglue bonds the black rubber o-ring material quite well. Handling the 1mm size while gluing might be a bit tough. I would try making a guide to hold the ends while gluing out of a piece of polyethylene (superglue doesn't stick to that).
    Nov 2008
    I'm not sure 0.5mm interference with the beam is going to be that noticeable
    I could be wrong though.....
    Quote Originally Posted by tobymack
    you are right but....
    -The Optik and LED engine has 39mm outher diameter!
    -The housing has 40.4mm inner diameter which can't be raised!
    - so with a 1mm O-ring i get 38,4mm inner diameter of the beam
    - with an 1,5mm O-ring i get 37,4mm inner diameter of the beam - it is not getting better
    ..just ride...
    Go to an auto parts shop and buy a "liquid gasket" or a "gasket maker"
    CNC LED light housing for DIY projects
    Toby
    Thanks for the link - i contacted them and they also have a 39x1mm O-ring!
    Had to take 38pcs, so if somebody needs one....
    ..just ride...
    If you haven't purchased already... maybe a custom-cut o-ring from silicone sheet? Ebay has 'em, as simple sheets and as "silicone baking sheets". I just got one that's fractionally over 1mm, smooth both sides, and go-fast red colour.
    The study du jour: can one's reputation be artificially inflated by simply putting a request for rep in one's sig?
    I'm afraid it's too late!
    I have now 38 o-rings in 39x1mm (was the minimum order quantity)
    ..just ride...
    Dirt Deviant
    Reputation: savagemann's Avatar
    Whitedog. I have a great solution to the min order issue.
    Just make and sell some of those housings to use up the extra orings that you had to buy......= )
    It's a good design and I'm sure you could sell a few.
    Look, whatever happens, don't fight the mountain.
