Results 1 to 5 of 5
    Bike Geek
    Reputation: norcalruckus's Avatar
    May 2005
    new LED's v.old headtrip
    Ok, I have an old headtrip, 10w halogen. It works ok I guess, I commute with it and do the occasional off road ride with it. Now, is it worth it to buy one of the new generation of LED lights for about $100? Will these lights be brighter and an upgrade?
    Straight up, are these new LEDs more powerful than halogens for the same wattage?
    RIP AL DAVIS
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by norcalruckus
    Yes, LED gives you more light per watt than halogen.
    Bike Geek
    May 2005
    worth it
    so the minewt usb i s definitely an upgrade. I think that is what i will be shopping for pretty soon.
    RIP AL DAVIS
    Minewt is an upgrade in size/weight/run time/cool factor.
    The minewt is rated around 150 lumens. Halogen lights produce 18 to 20 lumens/watt.
    The minewt should be bright enough for commuting.
    Trail riding might be a little challenging.
    If you are a light on the bar sort then consider the Minewt X2 Dual. If you are looking for a bright helmet light then it is hard to beat The Amoeba. 400 watts of LED power and a helmet mounted battery. The Amoeba is available in the classified section here on MTBR.
    BBW
    BBW is offline
    Reputation: BBW's Avatar
    Let me tell you my perspective
    I started night riding back in 2004. I went from little POS just enough light to be seen to my first awesome halogen light for serious off road (very technical and steep downhills with killer climbings). I bought a 12w Jetlite. Everywhere I went people were amazed by the quality/quantity of light. problem was that it weighted like a newborn (it was around 2 pounds for almost for hours and it costed me 180$)
    After using it for 5 YEARS with the same bulb and same battery, I started to hear about those HID lights, bought my L&M ARC and what a light, then I started to hear about those LEDs that were lighter, more efficients and thoughers. I bought a Dinotte 200L and I liked it A LOT. The a friend was amazed by the little thing and bough it from me. I got the 600L and I wanted to match the ARC with a good LED. I got a killer deal on a Lupine Wilma and I have spent a crazy amount of money in lights. I am a trully light-a-holik.
    I was perfecct with my 12W Jetlite and didn't care about the weight so if you are a weight w. OK, if not, 100$ are not going to give you a great LED. 230$ will give you a better and lighter system..
    Cheers
