Results 1 to 6 of 6
    Need help picking new battery and run times.
    Hey All:
    I need a new battery for a Turbocat Helmet light. 15w bulb and I believe it's a 4.8w bulb.
    If I buy a 7.2v Nimh 5Ah battery, what would the run time be. What is the formula since this is overvolted.
    Or I wouldn't mind 4/3 A cell battery. Lighter. What's the highest mAh rating you have all seen w/ these cells.
    Batteryspace has good selection. Any other sites to compete w/ them.
    MB
    Dr. Beat
    THe TurboCat folks are the nicest, most helpful, and reasonably priced around. I would call them directly.
    Don't understand from your info what you have or what you're asking. You say "15w bulb and I believe it's a 4.8w bulb" Well which is it 15 or 4.8? Can't be both. Is a 4/3 A cell 1.333 Amps (four divided by three) or do you mean a quantity of four 3 Amp cells? What is "Lighter"? What the heck! Just hook it up and see how long it is lighter with 1.333 amps or is that kilowatts?
    Person
    Quote Originally Posted by wmodavis
    It's most likely a 15w 4.8v bulb.
    I assume the old battery was 6v, so the bulb is already over-volted.
    Going to a 7.2v will make it a lot brighter, but the bulb may not last too long if it's old.
    There was a chart on here a while ago that helps with calculating run time when over-volting, will see if I can dig it up.
    Hey Baulz:
    Your correct. I must must have been tired when I wrote that like I am now.
    If you can dig up the chart, that would be great.
    MB
    Person
    Quote Originally Posted by mb323323
    Hey Baulz:
    MB
    Here is the thread where I found the chart, some good reading in there.
    Overvolted 20W hal vs. 13W HID
    And a direct link to the chart.
    http://nordicgroup.us/s78/wattslumens.html
    It's all based on 12v lights, but you should be able to re-calculate for your lights. It's too early in the morning for me to do much math.
