Results 1 to 12 of 12
    Feb 2006
    my little light .
    270 gr for a dual lamp xp r 5 and 4 battery configuration . A lot of light and a lot of time . I must to put it on the helmet . Very easy do it and without expensive material or tools .
    Internet Biomecanical studies . Just ask me if you want to ride better and more confortable..... PM .
    recognize the slowness
    Reputation: jbflyfshr's Avatar
    brilliant!
    Is the housing made from an LED flashlight?
    I have no tools to machine so this type would be perfect for a simple DIY'er like myself.
    List the build if you would.
    JB
    "mountain biking and flyfishing, what more do you want?" - Yeah, I said it
    May 2005
    Looks nice! Some more details please.
    Nov 2007
    Nice! A couple more pics and how you built them please
    Feb 2006
    Y get two controler and two r5 led from dealerextreme , a set of bottoms , o rings , 4 batterys 18650 and a heatsink thermal . I get one dual head magicshine
    http://www.dealextreme.com/p/5-4mm-m...864-25cm-32753
    to do all the conections , just cut the two female and use it to put the leds . One female reused to the battery and the other one to back up for other lights .
    The leds are this ones....
    http://www.dealextreme.com/p/cree-xp...6mm-base-44306
    And the boards.... this one . it work at 1200 mah maximum , so it dont get burned of hot at max power.The led can work at 1500 .
    http://www.dealextreme.com/p/3v-8-4v...mm-6-3mm-26108
    One switch for on and for change the modes ........
    http://www.dealextreme.com/p/clicky-...mm-5-pack-5588
    Thermal of course .
    http://www.dealextreme.com/p/heatsin...ease-like-4593
    Somes o rings , to seal the light .
    http://www.dealextreme.com/p/water-t...m-20-pack-5634
    A 4 batterys ..18650 standar .
    The battery are solder 2 in series and 2 in paralel so i get a 7,4v and i can charge with the same charger of the famous magicshine that i have one .
    The mount of all is very easy , dismount the flashlight , and cut the midlde body to reuse it as close of the light . solder the led to the controler and put in the middle two 1c coin with termal paste put a o-ring in between the cristal of the flashligh and the reflector , insert the led-control inside and you have the easy parts .
    Now the closer . You must to solder a small spring ( i cut from the flashlight) to the positive cable and some amount of solder to the negative and it too the border of the body. To have all the parts in its place i use a termal silicone .
    I must to take some pictures.....
    So now you can thread both parts and the light is ready .
    Tidy little light there. Nice work.
    Reputation: bncrshr77's Avatar
    What light did you sacrifice for this?
    A waste of time it is is
    Reputation: emu26's Avatar
    Really nice looking light linuxxx.
    I think most of us are interested in what you have used for a housing and what you have done to modify the housing, if anything?
    Feb 2006
    I get a very cheap light from my local chinese shop , 2 euros , about 3,5 dolars , similar to this in dealer..
    http://www.dealextreme.com/p/black-c...ed-1-aaa-24126
    For my the most important part is that i can unthread the light in 3 parts and full dismount it.
    Here i post a few more pics .Sorry for the bad quality , my movil is really old.
    You can see the middle part of the flashlight before cut it . I cut just when finish the thread , so i can use it to thread it to the front of the light where go the led , the controler , the disipators ( 2 coins ) . Very easy i think.
    Feb 2006
    On the helmet .
    Reputation: TwoHeadsBrewing's Avatar
    Very cool, thanks for sharing. I'm wanting to do my first DIY build and this looks like a good setup for starters. Any advice for a beginner?
    "Got everything you need?"
    Feb 2006
    do a good diagram with colors + and - of were must to go each cable. I broke one led , not expensive but a lot of time waiting for its.
