Results 1 to 6 of 6
Thread: Mr16 Led Bulb?
    ADV
    ADV is offline
    Mr16 Led Bulb?
    Here is my setup I am running 15 watt mr16 halogen bulb and a 14.4 battery. This works great for about 2 hours befor battery is dead. I would like to go to a LED bulb any ideas?
    You can buy a DIY E27 housing from dealextreme.com and an upcoming 3 XP-G module from Quazzle: A nice alternative to P7 LED (1100 lumens guaranteed)
    You might want to be careful because these are 12v, but these may be an option.
    http://www.ledliquidatorsinc.com/MR1...light_bulb.php
    Reputation: mtb_robs-x's Avatar
    Dec 2009
    your housing, does not look, it's an MR16 ?
    looks like a mag head.
    almost all of the MR16 LED's, are longer then a standard one,
    as such, does not fit.
    the angles/deg and led colors are a mixed bag , you never know what you get,
    or if you going to like it.
    you running 15W on overvolt 14.4V , be 22W,... and gets dimmer as it gets down,
    more runtime = bigger battery
    the MR16 LED's are expensive, considering, you need a housing for each + misc,
    $30 + 30 , + cable ,connector, misc,..
    what works for me,
    - bigger battery
    - add a MR16 LED
    need at least 2 lamps, offroad, 3x,
    non of the lamps died on my , at 14.8V ... 16.2V max
    so all those 12V work ok. most work with 3s 11.1V packs too,
    even 10V nimh,... not the 3 led ones, on 10V,..
    PM me, measure the lamp inside size,... show some pictures,
    if you want to keep / salvage/ mod it. I have loads of MR16's LED's,
    no, it's not free, no it's not the cheapest, no it's not the brightest.
    cheers, Rob
    Quote Originally Posted by ADV
    DIY battery + light working on it
    Reputation: HuffyPuffy's Avatar
    If you don't mind doing some modification you can easily fit LED's into that light. I have several older modded mag lights that are still very usable - a couple P7's, and couple Q5's (one is a quad bikelight that throws pretty darn good for an older light), the other uses a Dealextreme "drop-in" module.
    Dealextreme.com has some "drop-in" modules that would probably fit (may require some filing of the module though). I found that the DX module I used in one light did not make good contact though, so I stuffed some aluminum foil in the gap which helped with the heat transfer. Made for a simple upgrade to a maglight. This is the one I used, and it is quite old, but there are newer and better modules which would probably fit too:
    http://www.dealextreme.com/details.dx/sku.9358
    EDIT - note that the XRE modules are generally going to be a very tight beam, P7's are a better for flood.
    If you want to see what you can do with that light, I'd suggest checking out CandlePowerForums "Homemade and Modified Flashlights" section:
    http://www.candlepowerforums.com/vb/...splay.php?f=17
    They are usually at the cutting edge of cramming LED's into maglights
    Quote Originally Posted by mtb_robs-x
    LOL...did you pick that up by reading the "Maglite" label? LOLOLOL
