Results 1 to 3 of 3
    One Gear
    Reputation: .40AET's Avatar
    MagicShine Wiring Problems
    Looking for some help... A friend that I ride with has a MS that keeps going out now and then. I looked at it and couldn't get it to reproduce the problem. He said that as you twist the wires around the red light on the back of the head also comes on. I tugged, pulled and twisted everything and couldn't find a problem. The solder in the head looks good. I didn't pull the battery apart and check the board.
    Any good ideas????
    Jan 2009
    A pretty common problem ime.
    I posted this on another forum in response to the same symptoms:
    "I had this on my original MS. It went intermittent where the head unit plugs into the battery. A gentle wiggle about on the worktop isolated it.
    I tried the Maplin connectors but they will no longer be 'weatherproof' and come apart easier then the MS ones out on the trail. You also have to do a fiddly solder in the plug and socket (live wires in the battery side) and the strain relief isnt great (the grommet / throat bit seems too big) so it didnt last long.
    Next I got a MS 'extension' lead from DX (I also saw them for sale online in the UK recently). I cut this in half to use both sides as 'pigtails'(if that's the right term?). Then cut the original cables short of the dodgy connectors (for the battery side you'll need to cut the inner + and - separatly or you'll short the battery). Some easy wire to wire soldering, heatshrink and self amalgamating tape: job done and still working.
    Edit: one of these: http://cgi.ebay.co.uk/Extension-Cabl...item33642883ba
    Take care if / when soldering the battery side cable. It's live remember."
    One Gear
    Thanks, I'll start there.
