Results 1 to 2 of 2
    magicshine 808 driver substitute?
    A buddy offered me a frame in exchange for working on his MS 808 that quit working. I can't pass that deal up.
    Opened the light up, and found a lot of rust/corrosion on the switch assembly on the driver.
    This is the older P7 model. (1st gen)
    I'm going to try replacing the switch first - the light will blink on for a instant about every 3rd time you plug it in, so the P7 is working.
    If the switch replacement doesn't go well, I'll throw a new driver at it.
    I know that DX had sku 162787 that would have been a good replacement, although 2A on high is a bit down on power over stock.
    More important, it is out of stock, who knows if it will ever be back.
    Anyone got any other suggestions?
    May 2005
    I worked on a couple of the early MS lights and found broken connections on the inductor caused by not having the inductor glued to the PCB and relying on the leads for support.
  1. fox green 10wt, looking for substitute
    By desertrat423 in forum Shocks and Suspension
    Last Post: 09-10-2016, 08:59 AM
  2. Chain whip substitute
    By bsieb in forum Tooltime
    Last Post: 09-22-2015, 05:50 PM
  3. Substitute for a Shimano TL-FH40?
    By cjn1014 in forum Wheels and Tires
    Last Post: 10-05-2012, 06:18 AM
  4. Cheap Substitute
    By Sarguy in forum Wheels and Tires
    Last Post: 11-07-2011, 09:18 AM
  5. Rohloff Gear Oil Substitute
    By wensiaw@pacific.net.sg in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2011, 12:58 AM
