Results 1 to 3 of 3
    Lower Thermal Resistance for XLamp® XP-G White LEDs
    Update from Cree: Changes to XPG
    • Lower thermal resistance: 4 C/W
    • New tape drawing
    • Added color shift data for warm white
    • Calculated flux values for 700 mA, 1000 mA, 1500 mA
    http://www.cree.com/products/pdf/XLampXP-G.pdf
    What does it mean: the ability to remove heat from the the die has dramatically improved
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    Reputation: spankone's Avatar
    performance/lumen's drops as heat builds up, so the cooler it runs the better. I'm not a led geek so I cant tell you any thing more than that
    nothing to write home about.....
    the XML is 2.5C/W , lower number means it runs cooler.
    the number is also, just for bare LED ,...
    that means, by the time it is mounted on the star board, it is even worse,
    probably by a factor of 1.5-2x .
    for an XP-G at 1.5A max, on a star board, would mean it's at least 32C hotter,
    more like 35-40C plus. with multi-led, add 10C.
    these are my bender numbers, my thumb x pi,
    cheers, Rob
  1. Mounting of Leds - thermal performance
    By cdcdcd in forum Lights DIY - Do It Yourself
    Last Post: 07-13-2009, 09:33 PM
  2. lower pressure= less rolling resistance!
    By foot hill in forum Wheels and Tires
    Last Post: 06-06-2008, 09:29 PM
  3. Replies: 29
    Last Post: 05-16-2008, 09:43 AM
  4. Wide tires at low pressure have lower roll resistance
    By Phantom44 in forum Wheels and Tires
    Last Post: 05-26-2006, 09:13 PM
  5. Bottom-Out resistance for 2004 White Bros DH 2.0
    By DHMIKE_661 in forum Shocks and Suspension
    Last Post: 10-08-2005, 07:30 PM
