Results 1 to 27 of 27
    Barrington Womble
    Aug 2010
    Low voltage warning LED
    After building a CuLite style light a few months ago I have caught the bug and I am now on my third light build. Thought I would go bigger and have gone for a Triple XPE powered by 4 18650's through a dimmable Black Cat 690mA driver. Would love to fit a battery status/low voltage warning LED but my knowledge in this area is sadly lacking. Any ideas guys?
    Quote Originally Posted by cagliari
    After building a CuLite style light a few months ago I have caught the bug and I am now on my third light build. Thought I would go bigger and have gone for a Triple XPE powered by 4 18650's through a dimmable Black Cat 690mA driver. Would love to fit a battery status/low voltage warning LED but my knowlege in this area is sadly lacking. Any ideas guys?
    Use a driver from Taskled: http://www.taskled.com/
    The have the low voltage led function built in. You just need to wire a LED and set the voltage cutoff.
    They cost a little more than the one you want to use, but IMO, they are well worth the extra $$.
    Jan 2009
    here is something i have found but not tried yet
    http://www.4qdtec.com/batty.html
    Barrington Womble
    Aug 2010
    The Black Cat driver, switches LEDs etc are built, tested and being put into the housing! Don't really want to spend more on a new driver, this one seems to give the output I need. The status/low voltage LED was an afterthought. Thought if there was a simple(ish) solution it would be nice to have.
    Cheers.
    Barrington Womble
    Aug 2010
    Quote Originally Posted by whattingh
    Look like some good ideas. I can see the 1st circuit working with a few small changes. Will have to see if I can cobble something together and see if I can squeeze it into the can.
    Cheers.
    A waste of time it is is
    Reputation: emu26's Avatar
    Haven't tried this one yet but I book marked the page for the next build
    Aug 2010
    I am using 2x JUNSI CELL LOG 8S units tiny smaller than a match box and back lit amazing units. and rugged.
    http://www.hobbycity.com/hobbycity/s...itor_2-8S_Lipo
    These things really are the duck's nuggets. I log my cells voltage and down load it to my laptop after the ride - easy to see which cells are weaker than the others (and may need replacing !).
    There are lots of cheaper units on ebay
    http://shop.ebay.com/i.html?LH_BIN=1...4.l1581&_pgn=2
    Reputation: HuffyPuffy's Avatar
    I was going to use this design for a battery monitor until I decided to use a microcontroller to monitor voltage.
    http://www.flickr.com/photos/jonatha...es/2608325845/
    I posted some pics of it here.
    Barrington Womble
    Aug 2010
    Thanks for the ideas guys, not sure if any will fit inside the can but sure I will get something in the batt pack
    May 2010
    Quote Originally Posted by emu26
    Great, I've just managed to scavenge the parts from a old computer board and setup to light at 6v gives a few minutes warning before power is cut out.
    I'm going to put in a small trim pot to find the sweet spot on the discharge curve.
    Aug 2010
    This one is getting good reviews on the RC forums:
    Chargery Battery Saver BS6
    http://www.chargery.com/cellSaver.asp
    May 2010
    Quote Originally Posted by MrLee
    I got round to wiring up with a pot, the led starts to glow as it reaches the voltage, anyone know of an easy way to make it a harder cut in?
    Barrington Womble
    Aug 2010
    Quote Originally Posted by Pepster
    WOW! looks like this is pretty much what I want. Audible and visual warnings and not too big. BUT can it only be used with a balance connector?? Does anyone know? My battery pack is made up with 4S LG 18650 cells in a 4 cell holder. Cells are taken out for charging so no balance connector wired in.
    Wire your own connector and plug it in. I'm using BM6 on the same connector that I'm charging my 2S and 3S pack.
    Aug 2010
    Quote Originally Posted by Toaster79
    That is what I did. but... I bought some siht quality 6cell balance port extension harnesses and the intermittent alarm drove me crazy. Then I found some high quality silicone wire harnesses at my local RC store http://www.modelflight.com.au/ and every thing works perfectly now.
    Once you have soldered a balance harness to your batt pack, you can use a $30 RC balance charger, (is the best method, and will give you 500 cycles on Li-ion) and leave your cells in the pack.
    The RC guys discovered long ago that by not monitoring Li-ion/Li-po discharge (eg 3V min) and not balancing might give 20 - 100 cycles, vs properly monitoring and balance charging gives 500 cycles.
    Aug 2010
    I just received an email from Jason Wang of CHARGERY "BS6 is not available, BM6 is suitable for you, correct?
    If you agree, you can buy any products made by CHARGERY from me directly."
    FYI
    Aug 2010
    I have just ordered 2 of these:
    RC Lipo battery monitor buzzer with LED warning light
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=270487655242
    They are small. I will report on them when I receive them.
    I found this post a while ago. http://www.rcgroups.com/forums/showthread.php?t=270580 I now feel that that balancing the battery is critical. Watching the battery charge and seeing the balancer led's react lets you see how "out-of-balance" the packs are. I also noticed that no matter how the pack was used, it ALWAYS charges out of balance!!! The balancer citcuit that Dan B designed has some cool features. One is that the balance transistor needs 1.2 volts to turn on, where as the transistor that turns on the led only needs .6 volt. So the balance led comes on before the balance function starts. I used a common hookup, so I can use my balancer on 3-cell, 4-cell, or 5-cell batteries. Here's a picture of a 5 cell battery fully charged. Low voltage warning LED-battery-balancer.jpg
    I have used these. These will work with out a balance connector. They are not the best since they only look at the packs total voltage rather than each cell. They sure are small and cheep though. They are also available in 2-5s versions for different packs. Really better suite for lipo but good lion too.
    http://www.hobbycity.com/hobbycity/s...ery_Monitor_4S
    You can just stick it inside the light housing and wire it to the inputs of your constant current driver if you are using a simple on /off switch that breaks the battery connection to the constant current circuit.
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    I have been using these for a couple of years now both in RC helicopters and bike lights and they are fantastic. At $4 off ebay you cant go wrong. Best part also is that the buzzer is about 100db so even if you miss the lights changing colour you won't miss the buzzer, unless you are deaf.
    Nov 2008
    take a look this one....not bad
    47 x 32mm H10mm
    Aug 2010
    Link ?
    Barrington Womble
    Aug 2010
    Link ?
    What he said. This looks good
    Aug 2010
    interested as well... link? specs?
    Reputation: Goldigger's Avatar
    I've built the first one of these: http://homepages.paradise.net.nz/bhabbott/lvw.html and it works really simply and well!
    May 2010
    I built one of those two, had issues with it glowing so swapped it out to use a proper volt sense IC (MC34064P-5G) - http://uk.farnell.com/jsp/search/pro...sp?SKU=9666613
