Results 1 to 10 of 10
    looking to buy a 305 Edge, some questions
    Hello everybody,
    I'm looking to buy an Edge 305 and have a few questions.
    Is there anything stopping me using the 305 at night while in bed asleep? I want to graph my resting heart rate.
    I only ride at night, can the back light be left on for the whole ride?
    thanks,
    Mark
    Slow climbin' clyde
    On the resting HR while sleeping: Not that I can think of. Your average speed will be pretty slow, though.
    On the backlight: I've never tried, honestly. But since it's not a mapping GPS, I'd just tap it when you need to see the light. Once you turn the light on you just tap one of the top buttons and the backlight comes on. Still keeps good battery life that way, too.
    can anyone confirm the backlight can be left on permanently? The manual doesn't list the avaliable timeouts.
    Team Awesome
    Reputation: playpunk's Avatar
    Mar 2005
    I'm pretty sure that the timeout is pre-set. Why would you want it on permanently?
    trail rat
    Reputation: slocaus's Avatar
    Menu -> Settings -> Display -> Backlight Timeout:
    Stays On
    15 seconds
    20 seconds
    1 minute
    2 minutes
    My experience with night riding and 15 seconds timeout, I have the light on maybe 10 times in a 15 mile loop and my battery life is 2 hours compared to about 7 hours with no backlight during the day. I expect you would get maybe an hour with the backlight "Stays On".
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    thanks guys.
    I only ride at night, and at the moment I can't ride for more then an hour here due to lack of fitness coupled with the very steep terrain, so 1 hrs run time is probably okay. I'll have to try it and see.
    thanks for taking the time to answer my questions,
    Mark
    tiny rider
    Reputation: cartographer's Avatar
    You can extend run times with an external battery. I've used a little Energizer cell-phone charger that takes 2 AA batteries (rechargable if you want) and plugs into the USB port. GEOMAN also markets something similar which also charges the batteries when powered itself; this sounds pretty slick (http://geomangear.com/).
    I haven't used the backlight in a riding situation, so can't tell you how long it would work or how easy the Edge is to read in the dark. You can adjust the light level to match whatever your trail lighting is, though, so it would probably suit you.
    And yes, as mentioned, you can use it inside.
    Enjoy.
    Quote Originally Posted by link1896
    You'd have to make sure you don't have autostart/stop on, I'd think. Otherwise it won't record because you won't be moving. Otherwise, seems like it should work!
    thanks for the help guys, it's on its way.
    GeoMan
    Reputation: GEOMAN's Avatar
    Quote Originally Posted by cartographer
    Enjoy.
    Our customer feedback on the Tekkeon myPowergo is great so far.
    GeoMan
    We Ride!
    www.geomangear.com
