Results 1 to 3 of 3
Thread: Light question
    Light question
    I am starting a pedicab business and have a 12v deep cycle battery to run 6 LED running lights. I would like to hard wire a 2 bulb headlight into it as well. As an electrical idiot, is this possible? What resources/build guides should I use?
    Thanks in advance!
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    By bulb do you mean halogen or led?
    If halogen, like the 12v 20watt dichroic ones, just wire them straight to the battery through an on off switch, simple.
    If you want leds then something like this would do..http://www.cutter.com.au/proddetail.php?prod=cut144
    Just choose the leds and optics you want, hook it to your battery via an on/off switch and your away
    Reputation: zen bicycle's Avatar
    Get them in the US cheaper here
    www.ledsupply.com
