Results 1 to 7 of 7
    Light & Motion Lion battery mod
    Hi guys,
    Building converting a battery for a friend but running in to problems. The light setup he has is http://www.bikelights.com/Products/solo_logic.htm with a nicad battery 7.2 L&M sells a 11.4 lion.
    What I did was order a lion 11.4v from all-battery.com, opened the nicad pack and replaced it with the lion (which fits like a glove btw)
    So it works sometimes but when its fully charged it wont even turn on.
    My friend's theory is the PCB protection on the board, when I first plug it in spikes to 12,8v which the pcb thinks is a short so it shuts the battery off.
    I know the battery works though I use it to power other lights and is fine. But the solo logic is finky
    Anyway for me to get this to work, or trick the PCB?
    Reputation: bcane98's Avatar
    Are you saying you swapped a 7.2V NiCad battery with a 11.4 LiOn battery?
    Ride till I can't stand anymore...
    Ghost 5500...
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    I don't have one personally, but I'm pretty sure the L&M Solo lights have controllers that can take variable input voltage. So in Chowpay's case he can "swap" a 7.2V battery for something higher and expect it to work. Most Halogen lights are not like this.
    Chowpay, are you sure its an 11.4V battery?
    op
    www.msmtb.org - Mississippi Mountain Biking
    It Works!!
    Alrighty so actually there was no problem you can easily swap the 11.1v Li-ion in place of the crappy 7.2 nicad.
    The reason it didnt work was because the adapter I made to use a tamyia charger wasnt making contact well with the leads on the pack. just so everyone knows for 45 bucks you can have a 120 dollar battery as long as you keep your dead nicad shell to place the battery in. This is the battery to switch with http://www.all-battery.com/index.asp...OD&ProdID=1147
    Works good!
    Quote Originally Posted by chowpay
    Works good!
    What kind of charger are you using to recharge it? Do those type of cells require a balancer?
    Ghost 5500...
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Charger?
    Hi guys,
    This is not safe unless you are using protected cells (or a protection PCB for the pack) and a Li-ion charger. Lithium cells can explode if they are overcharged. Do yourself a favor and stick with NiMH cells unless you are willing to learn do the job right.
    Check this link:
    http://www.rcgroups.com/forums/showthread.php?t=719116
    These guys have documented over 100 cases of exploding ("vent with flame") lithium ion batteries. They are a wonderful product if treated with respect. But if you don't know what you are doing, you can burn your house down. How's would you feel if your hack set off a fireball in your friend's living room?
    Walt
    Walt, its a protected pack (click the link on the battery) .. i'm not an idiot haha.
    I did do it right btw. that pack is an 11.1v pack with protection circuit installed didnt modify the pcb at all. I thought that was the problem but it was much simpler than that , the connections were just not touching. now they are touching and everything works kosher.
    So now the light kicks ass for a mere 45 bucks.
    And here is the charger : http://www.all-battery.com/index.asp...ROD&ProdID=478
    I'll try to get some pics but basically what I did was make an adapter from the 3 prong L&M to connect to the tamiya connector on the charger. That was the hardest part. But what you can do is cut the connector off of the original Nicad charger and crimp a tamiya and use that instead. I just didnt have one to do that on so I had to make my own.
