Results 1 to 6 of 6
    Tá mé ar meisce.
    Reputation: BeerCan's Avatar
    Li-ion vs Standard Batts
    I am about to order my first set of lights (most likely dinottes) but I am really stuck on whether should order AA or Li-ion. Is there a +/- list on the 2 technologies somewhere? Does anyone have any experiences they would like to offer? They will be used mostly for rides 4 hours or less but I will be doing some endurance races/rides such as 12hr, 24hr and 100 mile races.
    thanks
    To see what is right, and not to do it, is want of courage or of principle. -- Confucius
    Come join me at the Swamp
    Reputation: flipnidaho's Avatar
    Li Ion lasts longer between charges and is lighter. AA is easier to find replacements for on the road. I use the Li-ion for saving weight (the batteries fit on top of my helmet and on the stem).
    Get the AAs, and get a couple of extra spare battery carriages from dinotte. Run them with good nimh rechargeables (I'm using 2700mah Sanyo). I find this option is far more versatile and cheaper in the long run. I can use alkalines when I'm stuck in some backwater town, and my nimh are also used for other applications when I'm not riding.
    When better nimh rechargeables hit the market, I can take advantage of them too. I've seen some counterfeit 3800mah Sanyos AAs when I was in bangkok, but that's another story..
    Tá mé ar meisce.
    Thanks Tinier good advice.
    Does any one know if the Li-ion batteries self discharge like the NiMH one do.
    Are recharge times for Li-Ion very long, I know it capacity dependent, but is it typically 2-3 hours or 12 or more to get a full recharge from a discharged state?
    Reputation: Lumbee1's Avatar
    Dec 2004
    Quote Originally Posted by BeerCan
    I use a 4hr smart charger for my Li-Ions and a 3hr smart charger for my AA's. The capacity on the Li-Ions is much better than the AA's and they don't suffer from the self discharge problem NiMH has.
    aa
    good points
    common
    cheep
    fit lots of chargers
    use in lots of devices
    available in different chemistry's (alk, nicd, nimh.)
    bad points
    discharge
    more needed / heavy
    li-ion
    good points
    need less / light weight
    last longer for size
    no discharge
    bad points
    uncommon
    expensive
    no other uses
    special charger
    there may be other points to consider
    but when you get to a certain size then the weight / size issue
    becomes more important
    for example on a set of lights using 14v
    then you need 12aa
    but the same li-ion pack will have 4 cells in it (a little bigger than the aa's)
    Alex
