LED and Driver question 2 for 1!
1. Can someone quickly tell me the difference between XM-L 280lm vs XM-L U2 emitters?
2. I have a couple 8xAMC7135 drivers and was wondering... when soldering past them, on the back plate, do I just solder (+) to center and pick any place on the edge to solder (-) to? If I need to post a pic, I can.
Thks
1. No way to compare. The 280 lm is a value for light output, the U2 is a brightness ( bin code) classification.
2. If you are talking about battery connections, then you are right. If you mean + and - for the LED, then you are not right.
Sorry, still trying to figure this out... Ok... then how about this:
led 1: Cree XM-L Star LED - LED Supply.com
vs
led 2: Cree XM-L U2 LED Emitter with 20mm Base
Just trying to stay away from DX for right now. I have a couple each of these by the way.
2. Ok then I think I am right when I say past - I meant furthest solder point away from source being the LED. Also same as backplate or backside of the Driver.
But yeah, I should have said battery side. lol.
Thanks Vancbiker
edit: with the LEDs - some of the terminology, I am still trying to nail down. :/
The LED Supply one is a T6
Understood. I see why y'all sometimes say a 'T6' or a 'T4' and now perhaps a 'U2'.
So much to take in since I walked in here earlier this week...
In other news, my phucked build is all but done. Waiting on 18650s to build a suitable pack. Tested with some crappy AA batts. Modified it slightly with a switch on top.
AND it got a T6. lol....
If you're using this 7135 board - all connections can be made on the front side if needed. EL34 has a nice writeup on ways it can be wired:
2800ma Multi Mode Driver Board
Thanks. Great right up. I had not seen that. The mode info was most useful. I currently have it mode 1 but may change to mode three using his trick.
Do you guys like having the strobe option on helmet lamps?
Strobe is useless to me on everything but a taillight. It really doesn't work well when trail riding at night.
Sent from my DROID RAZR using Tapatalk 2
- You may not post replies
- You may not edit your posts
Forum Rules
