Results 1 to 7 of 7
    Nov 2007
    L33.2MC - Other Optics?
    Hey Guys,
    Other than the 20mm optics which are readily available for Quazzle's triple XP-G, are there any other larger/better options?
    Thanks in advance
    Dec 2009
    For the triple XPG, I think the only option is 20mm
    Other models are available here from Carclo http://ledsupply.com/carclo-optics-xpg-3up.php
    As for the single XPG, there might be more options, if you find a holder that's compatible with the 14.6 mm base. Then again, I don't even see an optic on the order form that works with the L31 series, they all look like they fit the L30 series P4's.
    L332 is designed for 20mm optics only.
    Nov 2007
    Well, that makes it easy!
    Bigger is better!
    May 2005
    Speaking of Quazzles light engines:
    Anyone know if itīs possible to use Regina on the single XP-G L312 engine?
    Dec 2009
    The base of a Regina reflector is 9.4mm and needs to sit flat on the LED's PCB. The Lux RC PCB has components that will keep the reflector from sitting flat against it, plus the pins on the reflector will not match up.
    Its designed for a 10mm round PCB like this.
    I'm interested in using the L31 too, just need to do more research...
    Regina sure won't fit on 10mm round PCB's like those unless you clip off the pins and file some wire routing.
