Results 1 to 3 of 3
    rider
    Reputation: Swami Scott's Avatar
    L & M replacement battery
    My battery is shot for my L & M ARC Nimh. Can I replace the battery with something from batteryspace.com? I realize that I might have to splice connectors. I see that the L & M have 3 pins so I'm wondering if they're 2 or 3 wires in them??
    Ss
    Do It Yourself
    Reputation: Homebrew's Avatar
    The Turbo charger uses thermal cutoff to determine charge termination (best method BTW) so unless you want to get another charger, you should reuse the thermister & connections from your old pack. Personally, I would rebuild with new 4/3A cells rather than go with some Batteryspace crap.
    Long Live Long Rides
    Agreed- batteryspace batteries are terrible. Go with Homebrew's suggestion or just get the L&M battery. They are not cheap but they are reliable and last a long time.
