Results 1 to 7 of 7
    L&M charger compatibility with NR Digital Headtrip 6V battery?
    Hello, and thanks for all the helpful DIY information on this board.
    Question: I have a spare L&M Multi-Chem charger for my two year old Arc NIMH. I just bought a 6V, 10aH battery from batteryspace that I'm planning to use with my old NR Digital Head Trip with a 2 conductor head. Can I use the L&M charger on this battery? The back of the charger says "Output: 7.2 - 15V, 1.8A", so I'm thinking I can't since my battery is only 6V?
    I have the old NR trickle charger, but it's not very "smart", and I don't think it would charge as fast asa the L&M. It doesn't say how fast it charges, but I'm pretty sure it's not as fast charging as the L&M charger.
    Another question: If I can in fact use the L&L charger, are there any tricks or issues with re-wiring it to work on the 6V battery? I'm assuming I can just take the female plug off the NR charger and put it on the L&M charger with the assistance of a multimeter?
    The new 6V battery is NiMH by the way.
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    Many NiMH battery fast chargers use a thermistor to keep them from overheating upon charging. Your battery is likely only a 2-pin version (+/-) that does not have a thermistor and, consequently, is not a candidate for rapid charging using a thermistor.
    This isn't a good match.
    So, any battery pack without a thermistor is not a good match for a rapid charger? This is the battery I ordered: http://www.batteryspace.com/index.as...ROD&ProdID=435
    If I'd ordered this one, I would have been okay? http://www.batteryspace.com/index.as...OD&ProdID=4456
    Is the L&M multi-chem really a rapid charger?
    GMF
    GMF is offline
    Mmm... Tasty
    Quote Originally Posted by rturanc
    Yes, it is a rapid charger, but it uses a thermistor to do that. Those batteries you linked don't have a thermistor (one does have a thermal fuse, though, which is different). You definitely can get non thermally based rapid chargers, but that is not what you asked...
    Oh, okay. Thanks for the clarification. What is the danger of using a rapid charger with a thermistor?
    Reason I ask is, I bought another one of these for a friend to fit his NR system. I believe it's an Digital Evolution with smart charger. I talked to NR, and they said it should not be an issue?
