Results 1 to 11 of 11
    L&M bulb replacement alternative
    I have a nimh arc with a blown bulb that i inherited from a friend and was planning on getting a direct replacement but my LBS was quoted $150 for the bulb alone. Are there any alternatives? The difficulty seems to be that the arc uses a standarc solarc ballast but due to the separate reflector uses a non standard bulb?
    Arf, he said.
    Reputation: mtbdawgJeff's Avatar
    Try calling L&M directly. I've heard some phenomenal customer service stories about L&M.
    Do It Yourself
    Reputation: Homebrew's Avatar
    It's a little cheaper ordering direct (and I mean Welch Allyn, not L&M):
    http://www.walamp.com/lpd/webstore/d...mber=M10N001-1
    Long Live Long Rides
    Quote Originally Posted by Homebrew
    So is that the same bulb? Can the casing just be taken off as the original just has the bulb as far as i can tell?
    Do It Yourself
    Quote Originally Posted by doogs
    Yes, it's the only 10W HID bulb without reflector that W/A makes. And this is the ballast L&M uses in case you're interested:
    http://www.walamp.com/lpd/webstore/d...=1083656696845
    Thanks for the links homebrew, so is this the same ballast that they use in the Li-ion version or is this different? i was thinking i might use a 11.1v li-ion pack i have lying around depending on how long the nimh pack lasts.
    The brezel of the L&M can be unscrewed? I tried but without success.
    Do It Yourself
    It's the same ballast for both NiMH and Li-Ion although I don't know if L&M add any additional regulation within the Li-Ion battery (maybe included in the protection circuit?). Here's the datasheet with all the info:
    http://www.walamp.com/lpd/files/data...evB_10watt.pdf
    The datasheet says maximum instantaneous voltage is 11.8V which a fully charged Li-Ion could easily put out even if it's just for a short time.
    Quote Originally Posted by rottweiler
    It more sort of pops off but its a *****!! I have a second arc thats not broken and im too scared to exert enough force to get it off its that tight!! I dont really want to replace 2 bulbs!!
    Check and see what the price of a HID 13w bulb is from Trail-Tech for their MR-11, it's the same Welsh Alyn bulb.
    Do It Yourself
    Quote Originally Posted by RandyBoy
    No, it's not. L&M is using the W/A bulb without reflector adding a custom L&M reflector. TrailTech is using the W/A bulb with built-in reflector. Again, see the datasheet referenced above for more info.
