Results 1 to 30 of 30
    Reputation: ktronik's Avatar
    kLite dual helmet light w wireless bar remote
    Spring has sprung and its already hot as hell!! so I built myself a new helmet light, to match up to my 1000lm dynamo light....now to go night riding!!
    This one has a control box with battery input and also a wireless bar mounted remote....as you know the Dynamo changes its power for any given speed, so I just cycle the helmet light via the bar remote when I hit a downhill section...
    6x XP-E2 @ 500mA ea lamp. Leds wired 3S2P on a B3flex (@1000mA) ~1200lm (on paper)
    Custom kLite 7 o-ring LED housing w integrated cable gland
    Custom 3D printed box and helmet mount, made for to fit the helmet
    hope everyone is well and still rocking it out, new website and dynamo product now LIVE, finished off on my new 3D printer...
    enjoy
    Ktronik
    kLite dual helmet light w wireless bar remote-img_1467.jpgkLite dual helmet light w wireless bar remote-img_1457.jpgkLite dual helmet light w wireless bar remote-img_1458.jpgkLite dual helmet light w wireless bar remote-img_1459.jpgkLite dual helmet light w wireless bar remote-img_1460.jpgkLite dual helmet light w wireless bar remote-img_1461.jpgkLite dual helmet light w wireless bar remote-img_1462.jpgkLite dual helmet light w wireless bar remote-img_1463.jpgkLite dual helmet light w wireless bar remote-img_1464.jpgkLite dual helmet light w wireless bar remote-img_1465.jpgkLite dual helmet light w wireless bar remote-img_1466.jpg
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Nice, digging the 3D printed parts
    What kind of material are you using?
    Quote Originally Posted by scar View Post
    3d printing is a full on head trip...once you relise you can make pretty much anything you want in, plastic (PLA, ABS, PET) or Wood or rubber or a clay like material, forget the name... all my bar mounts, helmet mounts, and electronic enclosures, tools to repair my fox forks are done on my printer...PLA plastic is super tough!! I made a 26mm socket for my fox fork, and it is tuff as nails. ABS plastic has flex, so is used for mounts, BOXs ext.
    I only started a few months ago with the printer and now, I have done all this...
    About Ktronik - Thingiverse
    you can make them pretty cheap, and there is lots of kits to try starting @ $200!! the same price you would pay for a rear hub...printbot is a cheap and simple one to start with, and tinkerCAD is a super easy to use cad program... mate every one should have a 3D printer if your all makey and stuff...
    Light freak
    Jun 2005
    Yes, I have been watching your progress with your 3D printed parts on your Facebook page. I got a buddy that just got a Makerbot, just waiting for him to get it fired up.
    Once you make one, you can just printout another for a mate...
    Well I have learnt a heaps! and what not to do is still very helpfull...
    if anyone needs help on where to start, PM me...K
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Nice work Mate. I have an UP mini 3D printer but still need to find the time to make something, but like you say the possibilities are endless
    Awesome! Could you tell more about remote control unit, TX/RX modules used, power supply for TX, possible MCU?
    ditto Toaster's request ^
    cool work on the 3D printing, hopefully I'll be ready to start learning about in a couple of years after I've figured out how to use my lathe!
    I think everyone needs both, lathe and 3D printer...I have seen people with 3D printers, 'print out' a mini lathe!! so you never know...I might get my Lathe yet...
    You know I would never do any hard work when doing stuff for myself, as I got a few orders on its just a full dodge quicky build...using the hack and slash approach...
    kLite dual helmet light w wireless bar remote-remote02.jpgkLite dual helmet light w wireless bar remote-remote01.png
    hacked up a mom action car remote, and put the relay in line with another switch to the b3flex switch input...both switches work the same, for all actions...
    in the main control box on my light is the receiver section and the bflex...only note is, you can't have the two, too close together when switching @ high power...
    hacked the sender with another 'tact' switch, tossed the remote cover and fitted glue lined heatshrink...other than that it works great...
    if you run a bar light from a battery, you would combine this sender circuit into the bag light switch unit, so you could have both switches on tap or both lights on the one switch...
    dino direct is where I got my little module...less than $10 shipped.
    enjoy
    Kerry
    What are the dimensions on the receiver?
    hi mate, module is 31.5mm x 32.5mm comes w a project case of, 36x42x25mm...
    Ah, too big to slip into a 22mm housing.
    Maybe something like this would also work.
    DC3 5V Remote Control ON OFF Relay Switch Receiver Transmitter Wireless Switch Mini 30*13*12mm Momentary Toggle 315MHZ-in Switches from Automobiles & Motorcycles on Aliexpress.com
    I am planning out a dual XM-L helmet light and would love wireless mode switch.
    badarse dude!! but if using 14.8v input, maybe use a switcher rather than a liner reg to drop to 5v...
    these are tiny!!
    http://www.pololu.com/catalog/category/131
    let us know how you go b ro!!
    Quote Originally Posted by shirk View Post
    Won't do. It's a toggle type remote switch. Press -> ON, Press -> Off
    Quote Originally Posted by Toaster79 View Post
    They have the ability to be set up as a momentary or toggled or latched.
    I was thinking of using this driver as it will operate with normal off mom.
    I have also found the one w a button on board, can be programmed for the 3 states....
    Since the RX module consumes so liitle power it could be powered with a singl cell from a pack. I doubt, there would be noticable difference in cells discharge.
    Can't see a issue for the batts with a center taped pack, but do feel you would have a more reliable operation from a voltage regulated recivier input, given the voltage range of your target cell.
    Not going to hurt to try, you using the 5v relay version?? What pack??
    Giving this thread a bump because I just ordered a wireless module from dino direct. Cant wait to have wireless functionality on my helmet light. Also ordered a 2 channel module to control the two h6 flexes that run the 42 xp-e leds on the ceiling in dads garage work shop.
    cool, please post pic with done///
    Reputation: HuffyPuffy's Avatar
    Awesome stuff, like the light and the mount. Checked our your stuff at thingiverse, very impressive. And now I know what to ask Santa for this year (though I probably deserve a lump of coal).
    Quote Originally Posted by HuffyPuffy View Post
    thx mate, lots of shit printers that will never work for sale, out there, hard to know what to get, drop me a line if needed...
    Still impatiently awaiting delivery of my wireless modules from dinodirec and just got an email about a delay. In the mean time I should work out a normal switch to go with. I like the little tactile switches you use, any idea of a part number. See quite a few different ones on digikey, mouser, frys.com ect.
    Hi mate I just get hem from eBay, think thy are 12mm 'tact' switch, should be pretty cheap, any will do, get a short stem button, that way you can shrink over the button for waterproofing....
    K
    Well my wireless relay module finally did come a while back but it does not seem to work quite like I hoped it would, there is no jumper or button on it and it does not seem to do momentary.
    It does look just like the one in the hand in the photo.
    Quote Originally Posted by ktronik View Post
ID:	840301Click image for larger version.
    enjoy
    Kerry
    HI mate, I have a few units here if you get stuck...
    code on unit is:
    A1217000HK01
    and
    UN1206293363L
    good luck with your project...
    K
    Thanks,
    I googled the numbers A1217000HK01 and UN1206293363L
    All I got was dinodirect hits one was for a wireless relay board that looks just like mine but says its toggle not momentary.
    There is a board on dino that looks like mine / one in photo with hand you posted and is described as momentary.
    The board I have has the following on the bottom, AK-RK01-12
    2011.10.24
    and one one corner it says Radiance in very tiny letters.
    I thinking I will never find a data sheet or schematic for the circuit so I should just buy the momentary version, hope it works and if it does then maybe mod mine to be the same and work as momentary.
    getting stuff you need from china is hard sometimes....PM me your addy, I will send you a mom version as I got a few spares....
    K
  1. Self action shots - camera's with wireless remote burst shot ability? HALP!
    By AC/BC in forum Photography for mountain bikers
    Last Post: 01-18-2014, 06:06 PM
  2. Helmet light with wireless remote switch?
    By TheNormsk in forum Lights and Night Riding
    Last Post: 10-04-2012, 02:19 PM
  3. Wireless control of your helmet lights
    By brad72 in forum Lights DIY - Do It Yourself
    Last Post: 05-31-2012, 04:50 PM
  4. Circuit for wireless handle bar mount remote control
    By bikerjay in forum Lights DIY - Do It Yourself
    Last Post: 03-08-2012, 03:35 PM
  5. Wireless Remote for Ipod?
    By krinksta in forum General Discussion
    Last Post: 06-17-2011, 11:12 PM
