    More carbon fiber please!
    Interesting find looking for new Nightsun XC batteries...
    $100 - $150 for new NiCad batteries from Nightsun. Talked to my Interstate Batteries rep and they have them for $40. P/N NIC0310. I can find a new water bottle and expanding foam with the money saved, lol. Just need to check and make sure Interstate is aware of Nightsun's shady color-coding reversal trick at the plug.
    Old man on a bike
    Having just found my old Nightsuns, ran across your post while researching battery alternatives. I do note the Interstate battery is only 2300 mAh, so much shorter run time (thinking of my higher capacity Nightsun battery). Still, cheaper than a Nightsun battery. Did you ever get one of these? Questions if you did: Was the plug the same type as the Nightsun or did you need to change it? What kind of package were the batteries configured in?
    suum quique
    I have not. What is the rating on the original battery?
    Old man on a bike
    30Wh and 40Wh is Nightsun's spec for their two dual light batteries (at 12V that's 2500 mAh, 3300 mAh respectively). So a bit less than stock 30Wh, much less than the 40Wh version. For $40 vs $100 or $150 respectively from Nightsun, it's a nobrainer deal still, especially if it comes with the same connector and a form you could use without modding, as long as the run time is okay for your use....
    suum quique
