 Originally Posted by pinkrobe
Tease!
Be along soon
just waiting for some pics to upload
click on the photobucket link. Also seen on CPF this orning. Looks good!
That is "effin' rad"! I can't wait the beamshots!
 Originally Posted by troutie-mtb
How many lumens for 16 emmitters @ 250ma
4 Cree MC-E M bin, so min. 430lm * 0,76 (@250ma) * 4 = 1307 lumens min
Easily beat Lupine Betty, which have only 910 real lumens. Not 1500 as they claim.
That looks phenomenal. Well done!
You wont believe the beam shot
I had to do it , a quick visit to the woods .
I only have the Nflex and 18 v drill battery I could use .
Now that is the WOW factor I was expecting 6 months ago that never happened.
and this is @ 250 ma per led ( thanks czarny_kruk for the maths )
Prepare your selves ,
If you have followed my beamshots then You will know the trees on the right middle distance are 75 Mtres away
the trees in the far distance are over 150 mtres away and dont show on many beam shots
untill now
I was expecting as some one commented on CPF a huge wall of light with no throw .
wow. sweet! This was probably asked before...but how do you get the inside corners to be right angles using mill?
Cheers Cytoe , this might sound daft but I chopped them out using a small wood chisel
with the Ledils you only need to square off the top 3 mm
holy crap. that is truly amazing. I can't wait to see full amperage!
I think it looks quite cool stood up
100% italian mtbiker
Tease!
Hype!
MUFC - Champions!!!
bloody hell Chris thats awesome... kinda makes me depressed looking at my sorry set up now
cant wait for pics once its fully up to power
 Originally Posted by odtexas
Very nice write up and pictures.
Alot more info than the CPF post I saw a few hours ago.
I had been following the CPF thread for a bit and still have the same question.
Will lithium ions be able to provide the amp draw at higher light output levels?
It seems the lithium polymers handle higher draws much better.
Any estimate of what the amperage draw will be at full power?
Inquiring minds need to know.
Thanks for the comments
I dont know about the power draw but the makita drill batterys are designed for abuse
fast discharge and charge . and I doubt it will see the full 2800ma much
only to to upset the betty owners .
at full power it will be drawing a tad above 2800ma
and am I right in thinking 3200 lumens ish
really impressed w/ the clamp. was that the hardest part?
Cheers
Yes probably took the most time
I should have made them as 1 large one and then split into 2
but I made each seperate so double the tool changes and each process
 Originally Posted by emu26
So your 4 up @ 250 mA has better "useable" light than the triple @ 500mA
Do you think this is because the triple was so damn bright over such a wide area that the reflected light coming back from trail side objects played tricks on the eyes and blinded you to the distant objects?
Do you think these things work better, for our application at least, the lower the input current?
Go on mate, take the triple back out and do the same test at 250mA to see if it changes the "visible" throw you can see
Oh yeah and as I said yesterday, really nice work
Thanks Stu for the thumbs up yesterday and about posting it
If I can workout which maxflex setting is the same per die I will give it a go
wow that looks sweet,hows the samples of the 3 led getting on?
aka RossC
The amount of illumination in those back trees is very impressive. I don't think you have had any light that has filled in the back section so well before.
Seems we have the answer to your early question of which MCE optic is going to be the winner. It is such a shame that these weren't the first optics to come out for the MCE, we probably wouldn't have been quite so unimpressed with the MCE then.
The brightness when run at 2.8 amps is going to be unholy!
- You may not post replies
- You may not edit your posts
Forum Rules
