Results 1 to 10 of 10
    Reputation: roxtar's Avatar
    How to figure out battery life
    What is the formula for figuring out expected battery life?
    For instance, if I run my double XML light at 3000mA how long will a 14.8V (4S1P) 2600mAh pack give me on high compared to a 3S2P?
    Democracy is two wolves and a sheep voting on what's for dinner.
    Liberty is a well armed sheep, contesting the vote.
    May 2005
    I convert everything to Watts for this type work. It will get you close but the only true way is to do a run down test.
    If your light is wired in series then ~6.4Vf x 3A = 19.2W. I'll round to 20 to sort of account for efficiency.
    Your 4S1P battery is 14.8V x 2.6Ah = 38.48Wh. I'll round down to 38.
    38 / 20 = 1.9 hour run
    A 3S2P battery of the same 2600mA cells would be
    11.1V x 5.6Ah = 57.72. Round down to 57
    57 / 20 = 2.85 hour run
    Rolling on 650b
    Reputation: Clipless in PA's Avatar
    I used this calculator when figuring out my battery needs. Again, its a ballpark estimate.
    LED Runtime Calculator
    Jun 2010
    A quick and easy way is to take the current rating of the battery divided by the current draw. in this case it would be 2600mAh/3000ma=0.87 hour. Another way to think of this is a 2600mAh battery can have a current draw of 2600mA over 1 hour.
    Metrology has nothing to do with the weather.
    May 2005
    Quote Originally Posted by n9tkf View Post
    This is totally wrong. Your formula ignores the voltage difference between the battery and LEDs. The OPs battery is 14.4V but the Vf of his LEDs is a bit below 7V. Because of that difference, the draw from the battery will be about half of the LED drive current.
    Jun 2010
    Ok. Now I know why my batteries last about twice as long as I calculated them to last. Thanks.
    Reputation: bwack's Avatar
    Quote Originally Posted by Vancbiker View Post
    It's been a while since I've posted here. I agree, on the battery side of the driver, the current is not the same as the led side of the driver, and since the driver is a constant power device, it's better to calculate Watt Hours.
    It's easy to add the efficiency to the Power calculation, and it gives a more conservative result...
    ~6.4Vf x 3A /0.85 = 22.6W (assuming 85% efficiency, maybe a bit harsh)
    Durration=1.7h ..
    What runtime did you end up with, n9tkf? Twice than 0.87h ?
    for those who don't want to do the math themselves, the runtime calculator linked in an earlier post does the same calculations - and you can dial in the efficiency where you want it as well.
    Jun 2010
    Quote Originally Posted by bwack View Post
    About twice .87 hrs. I totally misread the the question though thinking that 3000mA would be presented to the battery,not so.
    The LED calculator is a good place to start.
  1. Garmin HRM and Sensor battery life
    By mopartodd in forum GPS, HRM and Bike Computer
    Last Post: 01-30-2014, 01:30 PM
  2. Samsung Galaxy S3 vs Iphone 4 or 5 GPS ON battery life?
    By xnofriendsx in forum GPS, HRM and Bike Computer
    Last Post: 03-27-2013, 01:57 PM
  3. Battery life with Gemini Olympia 4 cell
    By gabby1 in forum Lights and Night Riding
    Last Post: 11-19-2012, 02:55 PM
  4. LED CREE battery life?
    By kevocastro in forum Lights and Night Riding
    Last Post: 11-12-2012, 01:19 PM
  5. Stava app w/iPhone 4s battery life
    By Broncstad in forum GPS, HRM and Bike Computer
    Last Post: 03-27-2012, 02:29 PM
