Results 1 to 3 of 3
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    How to calc burn time?
    I have an old blt helmet light with a 15 watt halogen bulb replacing the original 10 watt. I just picked up a 6 volt 8.5 amp/hr lead acid battery to replace my old 7 amp/hr. Is there a way to calculate the approximate burn time?
    This setup is an interim measure until I buy a new light, probaly one of the new led's that are conming out.
    Thanks.
    I got some bad ideas in my head.
    Singletrack Daydreamer
    Reputation: rockymtnway's Avatar
    Burntime = Volts X Amp Hours / Lamp Wattage
    6v X 8.5ah = 51 Watt Hours / 15w bulb = 3.4 hours
    Anytime. Anywhere.
    Thankyou. 3.4 hours should be fine for now. They had bigger batteries but the weight of the lead acids is prohibitive.
