    May 2013
    housing for led-tech 7xml pcb
    Hi all,
    i am looking into a 7 xml light which should be very light and small. Therefore i have designed a housing where i would like to get your thoughts and if anybody is interested in also getting this housing?
    The driver will not be in this housing. It is designed for the led tech 7xml PCB with14mm high optics and a 42mm glas screen.
    plese provide me with your thoughts and tell me if you are interested in having one of this housings.
    thanks
    Jeti
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by jetidahom View Post
    Hi all,
    thanks
    Jeti
    Not to put a damper on your design, but I personally prefer a design with the driver to be in the housing as this allows for thermal monitoring and throttling if needed. I think this is especially important for a light with 7 XMLs as this can generate a lot of waste heat which can degrade and damage the LEDs if not kept under control.
    May 2013
    thanks for the input. It will not be a 7000Lumen light for sure. There needs to be a lot of testing to get the sweet spot right!
    May 2005
    +1 on Kwarwick's suggestion. A small 7 XML light has the potential to cook itself quickly. In the years I have built LED lights, I have constantly gone smaller and lighter. I have come to the conclusion that about 1 sq inch of surface area per Watt of LED output works fine as long as there is moderate airflow over it. Stop that airflow for a minute or two and the temps rise quickly.
    If I were to do a design for a round 7 emitter, I would cut vertical fins on the body behind the emitters. I have no education in thermodynamics or anything close but intuitively believe that the shortest thermal path for emitter to heat sink fins is best.
  1. Replies: 1
    Last Post: 03-22-2013, 12:09 AM
  2. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  3. Can anyone ID this housing?
    By adrenalnjunky in forum Lights DIY - Do It Yourself
    Last Post: 08-20-2012, 07:06 AM
  4. Rear Derailler Issues: dirty housing, full housing, new housing?
    By TwoHeadsBrewing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2011, 10:49 AM
  5. New Housing Help
    By one4teen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2011, 12:49 PM
